MAF Reading at Idle
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Philws4
MAF Reading at Idle
Post by Philws4 » Mon Apr 30, 2007 9:17 pm
As above really, not had a chance too do any logs yet but got a MAF of 3.8g/s on tickover.
Is this about right for a custom remapped engine?
B5 S4
Uwe@Ross-Tech
RE: MAF Reading at Idle
Post by Uwe@Ross-Tech » Tue May 01, 2007 3:51 am
MAF readings at idle are not very useful. The peak value at full power is far more telling.
-Uwe-
Philws4
Post by Philws4 » Tue May 01, 2007 8:54 pm
Yeah i thought as much, i will try and get some time this weekend to do some logs.
Thanks for your reply.
B5 S4
flashyg
Post by flashyg » Thu May 03, 2007 11:34 pm
looks fooked 2 me
what does block 32 read also
+6 ish on all 4 measuring blocks?
Philws4
Post by Philws4 » Mon May 07, 2007 7:57 pm
Did my first set of logs the other day and i'm pretty sure the MAF is ok. :wink:
http://www.rs246.com/index.php?name=PNp ... ic&t=61125
B5 S4
AdamS4
Post by AdamS4 » Wed Jul 11, 2007 3:30 pm
I've just taken a drive and the max reading my MAF was 106.75, is that low ??
GrahamS4
Post by GrahamS4 » Wed Jul 11, 2007 3:35 pm
Yes. You did use all the revs didn't you?
AdamS4
Post by AdamS4 » Wed Jul 11, 2007 3:56 pm
Yes, that was at full RPM, 100% throttle
Will this cause lack of power ?
GrahamS4
Post by GrahamS4 » Wed Jul 11, 2007 4:05 pm
I would have thought so.
Philws4
Post by Philws4 » Wed Jul 11, 2007 10:14 pm
Get your new MAF fitted Adam and try again, i bet you will be surprised by the difference.
B5 S4
Return to “DTC / VCDS”
