same old errors driving me mad (Help)
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
flashyg
Post by flashyg » Sun Jun 11, 2006 2:12 pm
changed:
maf, dv's, lambda on bank 2 , n75, 126 valve, coolant temp sensor , thermostat, map sensor. No boost leaks at all system holds perfect pressure.
block 32 shows readings -4, -7 -4, -7 Approximate.
What on earth is going on . The car is driving me mad and I just cant figure this out it been going on for a long time and my warranty soon runs out.
Please Help.
6 Faults Found
17965 — Charge Pressure Control: Positive Deviation
P1557 — 35—10 — — — Intermittent
17545 — Fuel Trim: Bank 1 (Add) : System too Rich
P1137 — 35—10 — — — Intermittent
16622 — Manifold Pressure / Boost Sensor (G31) Signal too High
P0238 — 35—10 — — — Intermittent
16486 — Mass Air Flow Sensor (G70) Signal too Low
P0102 — 35—10 — — — Intermittent
16514 — Oxygen (Lambda) Sensor B1 S1; malfunction in Circuit P0130 — 35—10 — — — Intermittent
16534 — Oxygen (Lambda) Sensor B2 S1; malfunction in Circuit P0150 — 35—10 — — — Intermittent
Readiness~ 000 000
flashyg
RE: same old errors driving me mad (Help)
Post by flashyg » Sun Jun 11, 2006 6:56 pm
Could it be new dv's and a maf required
Could it be as above but external air pressure and intake temp sensor.
Any one got any pics or know where the intake air temp sensor and external air pressure sensors are for reference.
Nige_RS4
Post by Nige_RS4 » Sun Jun 11, 2006 8:45 pm
Gordon, probably worth a trip down to MRC to diagnose this one!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
flashyg
Post by flashyg » Sun Jun 11, 2006 9:33 pm
Thanks Nige.
I think the same, but the trouble is I go on holidays with the car in 3 days .
Any help greatly appreciated Please.
Gordon
Philws4
Re: same old errors driving me mad (Help)
Post by Philws4 » Sun Apr 29, 2007 10:50 pm
flashyg wrote:changed:
Please Help.
6 Faults Found
Readiness~ 000 000
Did you get to the bottom of the DTC at the bottom of the list?
Did a scan on mine this evening and got the same code i.e
16534 Oxygen(Lambda) Sensor B2 S1 Malfunction in circuit
P0150-35-10- Intermittent.
I cleared the DTC and went for a spin then checked again and so far not re-appeared but only a matter of time i guess!
Is this just a case of replacing the EGT,and on which side? ( I bet it's the awkward one, N/S!)
Also had 18048-Internal Control Module EEPROM Error
P1640-35-10 Intermittent WTF is that all about!!!!
This cleared ok and did not re-appear.
B5 S4
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 20 guests
