Received my vag com...
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
C-24
Post by C-24 » Mon Apr 16, 2007 10:25 pm
Hi,
it works. I can connect it to my both cars.
but, I don't know what to do with it now...
FATS ? Where do I get them ?
When you make a diagnostic, is your car running or just got the ignition on ?
I got a TONS of softwares for OBD, and none works, only Vag Com does! Is it because softwares are generally limited to serial port utilisation and not usb (mine is a KEY-USB interface) ?
How can I access the menu where you can record your runs (0 to 100km/h, 80 to 120 etc...) ?
Thanks,
I'm a little bit lost since it's a complicated thing.
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
Sebastian
Re: Received my vag com...
Post by Sebastian » Tue Apr 17, 2007 1:10 am
C-24 wrote:I'm a little bit lost since it's a complicated thing.
It's not that complicated, but it's what you make of it. :wink:
Suggestion, download the manual, grab your laptop and sit down somewhere and read through it. Most of the questions you asked yet are being answered on the first pages.
http://www.ross-tech.com/vag-com/tour/main_screen.html
Sebastian @ Ross-Tech.com
Return to “DTC / VCDS”
