does anyone have a list of what the DTCs ACTUALLY mean?!
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
fletchie55
Post by fletchie55 » Sat Feb 10, 2007 10:46 pm
I have run a fault code scan on the S4 B5 and got some stuff back that doesnt realy mean a lot to me, does anyone have a list of the codes, and what they actually mean in plain english?
for example what does key 1 adaption limit surpassed mean? or alarm triggered by terminal 15? what is terminal 15?!
im sure there is something on this site somewhere, but I can never find anything using the search!
thanks in advance
shineydave
RE: does anyone have a list of what the DTCs ACTUALLY mean?!
Post by shineydave » Sat Feb 10, 2007 11:12 pm
don't know whether this is what you're looking for
http://www.bentleypublishers.com/tech/a ... .table.htm
failing that try searching the ross-tech website
Dave
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Sun Feb 11, 2007 4:49 pm
It means your central locking system hasn't seen this key in a while and it *may* be necessary to re-synch it.
It means the terminal 15 turned on without the alarm having been properly disarmed first.
Terminal 15 is switched power (this is a DIN or ISO standard).
Bosch has a lot of good literature that explains how stuff works:
http://www.bentleypublishers.com/bosch/index.htm
High on the list:
http://www.bentleypublishers.com/product.htm?code=h009
-Uwe-
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 31 guests
