VAG-COM and non VW Audi cars
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
shineydave
Post by shineydave » Sun Jan 21, 2007 10:14 am
just showing my ignorance here but i was wondering if VAG-COM could be used with alternative software to scan Non VW-Audi group cars since all cars have OBD11 compatible engine diagnostics.
Dave
MarkB
RE: VAG-COM and non VW Audi cars
Post by MarkB » Sun Jan 21, 2007 10:33 am
Theres a generic OBD11 part to VAG-COM. Never used it though
Mark
shineydave
Post by shineydave » Sun Jan 21, 2007 11:33 am
so from that one would assume it was possible then? has anyone tried it with other makes?
Dave
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Sun Jan 21, 2007 3:14 pm
VAG-COM *is* software. Whatever interface lead you have (whether it's ours or some 3rd party on) is not VAG-COM.
Current versions of VAG-COM support pretty comprehensive generic OBD-II functions on cars that are use a physical layer for OBD-II that's compatible with the lead. Note however that there are 4 different allowable physical layers, and that VW only uses two of them.
For more info, see:
http://www.ross-tech.com/vag-com/tour/obd-2.html
-Uwe-
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jan 21, 2007 4:10 pm
works on new range rovers!
http://www.MRCtuning.com
shineydave
Post by shineydave » Sun Jan 21, 2007 4:16 pm
sorry, i wasn't very clear with my original post, i meant could i use the Ross-Tech interface with alternative software (or Vag-Com software) to scan non VW-Audi cars. from the answers above it would seem that you can depending on the type of car
Dave
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Mon Jan 22, 2007 3:18 am
Yes -- depending on the car. For example you can forget about most US-model Ford and GM products. Those use the two flavors of SAE J1850 as the physical layer for OBD-II.
It might help if you'd tell us what kinds of cars you're looking at.
Remember also that while OBD-II has been mandatory in the US since 1996, it's only been mandatory in Europe since 2001 (Petrol) and 2004 (Diesel).
-Uwe-
shineydave
Post by shineydave » Mon Jan 22, 2007 10:20 am
Thanks for that Uwe. i'm not looking at anything in particular, i was just curious after realising OBD-II was common amongst cars.
Dave
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 60 guests
