Only Dealer can reset this fault?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
viperbl
Post by viperbl » Thu Oct 26, 2006 2:33 pm
Mate has just bought an S3 (8L)
The ESP light is on the and garage he bought it from says this happened after the battery went flat and the AA gave it a jump.
I plug VAGCOM into it and under the ABS section it had the following fault
Lateral Acceleration Sensor (G200)
Electrical Circuit Failure
Now, I cleared the code (in VAGCOM), but it instantly came back.
The garage over here says that only Audi Dealerships can clear this fault??!?!?
MarkB
RE: Only Dealer can reset this fault?
Post by MarkB » Thu Oct 26, 2006 2:39 pm
No. fix the fault and the fault indicator will stay off
Mark
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Thu Oct 26, 2006 7:56 pm
Agreed. Although you may have to calibrate the sensor after fixing the fault.
If you're a registered user and you need help getting the sensor calibrated (once it's complaining about a lack of calibration rather than an electrical circuit failure) e-mail us.
-Uwe-
Return to “DTC / VCDS”
