Just got VAGCOM how do i measure data?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
BigDaz
Post by BigDaz » Thu Sep 07, 2006 8:58 pm
Just got my VAGCOM today , managed to run a fault scan and nothing serious appeared, How do I do log which tells me whats happening when I am driving, eg expected boost v actual boost , maf reading etc?
Daz
(step by step if poss :) )
CliveH
RE: Just got VAGCOM how do i measure data?
Post by CliveH » Fri Sep 08, 2006 9:23 am
Daz,
There's an excellent online manual here : http://www.ross-tech.com/vag-com/tour/m-blocks.html
Initially, I would use group 003 for ignition timing and mass airflow, and group 115 for boost.
Clive
ZeroK66
Post by ZeroK66 » Fri Sep 08, 2006 10:25 am
Hi Daz,
Took me a while to figure it out... but got there in the end. Hope the online manual helps you out. Give me a buzz if you are stuck. PM me for number.
Cheers,.
Return to “DTC / VCDS”
