DIS mpg reading - making it accurate
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Dippy
Post by Dippy » Thu Nov 11, 2004 1:43 pm
1) Monitor and record your average real and displayed mpg. This might take a few tankfuls depending on your driving.
2) Calculate the average discrepancy as a percentage.
Discrepancy = average DIS mpg x 100
average real mpg
3) Round this figure to the nearest 5
4) Adapt (function 10) channel 03 of the instrument cluster (address 17) to this figure.
My average discrepancy was 108% so I adapted to 110. Current average discrepancy is now 101%.
2001 Silver S4 Avant
Golich
Post by Golich » Thu Dec 09, 2004 8:03 pm
Top tip Dippy :thumbs:
jeffw
Post by jeffw » Fri Dec 10, 2004 7:23 am
Someone needs to get out more...... :biggrin2:
ChrisG
Post by ChrisG » Fri Dec 10, 2004 1:38 pm
this is what happens when you have two small children !!
As usual a real techie post from Dave !
ChrisG
CliveH
Post by CliveH » Mon Jun 19, 2006 3:10 pm
Very interesting and informative Dippy, thanks. (In case anyone's wondering why there was such a delayed reaction on my part, it's just been cross-referenced in another post!)
In order to get actual average mpg, miles driven is easy enough (as long as you remember to reset the counter of course), but gallons consumed is the tricky bit - obviously full tank to full tank, but how much is consumed from tank to tank? I struggle to get 55 litres in mine (on "empty" 0 miles tank, running on fumes) whereas the spec says the tank holds 62 litres...
Clive
david7m
Post by david7m » Mon Jun 19, 2006 3:29 pm
I have no idea what so ever you are talking about - but sounds great anyway :)
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
Dippy
Post by Dippy » Tue Jun 20, 2006 1:21 pm
Clive, you just need to record your mileage between fills and how much you fill up with. So for example:
Range - refill - real mpl - real mpg - DIS mpg - discrepancy
300 miles - 55 litres - 5.46 - 24.82 - 26.9 - 108%
280 miles - 53 litres - 5.28 - 24.00 - 25.7 - 107%
285 miles - 50 litres - 5.70 - 25.91 - 27.8 - 107%
300 miles - 59 litres - 5.08 - 23.12 - 24.5 - 106%
295 miles - 56 litres - 5.27 - 23.96 - 25.0 - 104%
The average discrepancy for this is 106% so the best adaption value would be 105
KayGee
Post by KayGee » Tue Jun 20, 2006 1:48 pm
Great post Dippy now if Mihnea hadn't got mine spot on when he did my remap I might actually have a use for it.
CliveH
Post by CliveH » Tue Jun 20, 2006 1:52 pm
Thanks Dippy, I knew you'd put me right :thumbs:
Now, I have a related question...oops, better start a new thread...
Clive
CliveH
Post by CliveH » Tue Jun 20, 2006 3:32 pm
Clive
Return to “DTC / VCDS”
