VAG-COM Faults - your help needed
Anyone seen this fault before?
From my RS6. It holds the car back. When the fault is cleared the car accelerates as she should , but the fault returns and she is held back seriously, sometimes causing the gearbox to hesitate.....
Address 01: Engine
Controller: 4D1 907 558
Component: 4.2l V8/5VT G01 0002
Coding: 0010752
Shop #: WSC 00976
1 Fault Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 01: Engine
Coding: 0010752
Shop #: WSC 00976
1 Fault Found:
RE: VAG-COM Faults - your help needed
Dunno, but I would not reset the code, it is there to protect the car. Best advice is to get it looked at, dealer or specialist.
It is booked in for the 21st.
The fault has been present for sometime, although on Saturday it lit the EMS warning indicator....
Took to dealer and the 'helpful' girl on Service Desk said "Your car is already booked in in a couple of weeks, so as it not misfiring....ignore it"!!!!!
I insisted a Tech looked at it, and they cleared the code and gave it me back
Hence I am here....
Can't believe she said ignore it! What if the engine gave way under load/speed and I had a major crash?
I asked her 'can I have that in writing', which is when she got really shirty!
Hence I am here....
I guess they wouldn't have given me the car back if they have looked at it and given it me back.
Just a bit peeved at the attitude of the young lady, never mind, we all have bad days.
Go have a word with her boss I'd say, you are their customer and have warranty.
Perhaps what they have done is all well and good, but you are entitled to a satisfactory explanation.
the evap emission control is the unit which vents the tank and charges the engine on cold start, it is friendly to the environment!
advice is: Check the vacuum hose going to the EVAP valve and make sure Ur fuel tank is sealed closed.
Both codes I believe are related, second code suggests pressure in the secondary air system has not reached min required.
Has car been a little slow to start on cold mornings with slightly more audible hiss / ring pitch on very cold start.
I think readiness code indicates all fine, any Audi tech should be able to speak this language- mine is an attempt. hope it is of some use and sense. G
I thought u went to Chester? They know their stuff, eh!
Re: RE: VAG-COM Faults - your help needed
PS: To be fair to Chester it was a Saturday and they were v. busy (I've calmed down a bit). My usual contact there is excellent, but was on holiday.
RE: Re: RE: VAG-COM Faults - your help needed
Damon, you know where I am - if you need it looking at sooner let me know
Thanks, Dave. Don't worry, service has been great. Everyone has bad days so I've put this down to an isolated issue
I am feeling better now the above diagnosis has been made. Isn't it funny, when your car's not right you feel down, like someone in the family is not well!
Sad really
Sad really
Re: RE: Re: RE: VAG-COM Faults - your help needed
Funnily enough I had this conversation with flashyg last week !!rs666 wrote:Thanks, Dave. Don't worry, service has been great. Everyone has bad days so I've put this down to an isolated issue![]()
Sad really
And no I don't think its sad -- when you have a car, any car but expecially when it's something special - you want and should expect it to be 100% , and if it isnt it grates a bit every time you get in the car.
At the end of the day dealerships are there to put things right, and if we aren't doing thingd right that just makes it worse!
RE: Re: RE: Re: RE: VAG-COM Faults - your help needed
Ah so flashyg was baiting you with his Chester comment!
Re: RE: Re: RE: Re: RE: VAG-COM Faults - your help needed
Maybe just a littlers666 wrote:Ah so flashyg was baiting you with his Chester comment!![]()
RE: Re: RE: Re: RE: Re: RE: VAG-COM Faults - your help neede
Loll, you are great guys C Audi. Glad u got it sorted. C u in the morning, I think your specialist treatment and work is superb.
