Hi does anyone know of any error free upgrade of number plate bulbs as the std ones are a bit too yellow and letting the side down?
Paul
Upgrade number plate bulbs
Re: Upgrade number plate bulbs
Hi Paul,
I upgraded some on a r8 last week for a customer, what year is the car?
Trups
Trups
Hi Trups
Thanks for the reply, It's a May 2010 V10.
Paul
Paul
Hi Paul.
You will need to go down the oem route I'm afraid, that's not all, I will need to build you a plug and play loom with a dummy bulb in it to cancel the error as you have the odd body control module so it won't let you have the LEDs and you won't be able to recode the module either.
The lamps which are oem audi from the 2012 R8 are £29 each side (I get these from audi) 1x plug and play loom using oem connectors is £15 and postage to the uk is £4.30 which is Royal Mail signed.
If you wanted them I can have them out to you mid week once I have ordered from the dealer.
Trups
Trups
Our man Trups fitted mine last week and is now up to date. Get the rest of the bulbs done as well whilst you're at it.
