Page 26 of 36
Re: light and strong Audi R8 V8
Posted: Sat Feb 03, 2018 5:02 pm
by classba
Speedr8 wrote:
Sat Feb 03, 2018 3:57 pm
Hi @classba
If you have the knowledge that the R8 V8 injectors make more throughput than the V10, then you take these.
If the high-pressure pumps of the V10 Gen1 are too weak, then you take the amplified version of the free market.
Tom
Tom, I think you will still struggle even with your say that the V8 injectors are larger/ flows more. The Gen-2 have double the amount of injectors compared to the Gen-1 and the most you can get out of them with an ECU map is around 650ps ( NOT BHP) maximum.
Anyway, best of luck again and hope you will hit your target. :beerchug:
Posted: Sun Feb 04, 2018 8:57 am
by Speedr8
Hi @classba
The problem with the V10 is not the fuel supply, but the necessary fresh air in the cylinder for it !
A good basis is the 610HP intake manifold and 90 degrees rotated TB for good uniform distribution of air to all cylinders per cylinder bank.
The smaller exhaust valves of the narrower contoured 610 engine in conjunction with the 610HP camshafts complete the package.
But perfect cylinder head machining is a prerequisite for this.
So do not worry, that will work.
It was also said that no 500hp in the V8 engine are possible and, I've done it.
Tom
Posted: Sun Feb 04, 2018 9:24 am
by Brooner
look forward to seeing the new V10 project unfold
Posted: Mon Feb 12, 2018 7:46 am
by Speedr8
Hi
The R8 was indeed already finished for the start of the season in 2018 but not since yesterday.
Reason are larger exhaust flaps with larger cross section.
The built-in flaps in my exhaust system have an inner diameter of 51mm with a tube inner diameter of 59mm.
The new flaps have an inside diameter of 59mm and have no edges.
The exhaust gas can thus flow through unhindered and more engine power is generated.
New flaps
The still installed flaps
Tom
Posted: Thu Mar 29, 2018 9:27 am
by Speedr8
Hi
Visually, something was missing on the front and I was not sure what that looks like.
But the decision was good to mount winglets.
Tom
Posted: Fri Apr 27, 2018 6:17 am
by Speedr8
So girls
As value preservation and the look because of, there was a mint R8 GT tailgate.
Positive side effect, the tailgate weighs 2.8Kg less than my modified series tailgate.
The weights in detail. Series 23,8Kg, GT 13,1 Kg, my modified 15,9Kg.
In addition, I could not resist and had to buy a set of carbon R8 GT mirror.
Less weight 0.53 kg compared to the facelift mirror.
Tom
Posted: Fri Apr 27, 2018 7:11 am
by bam_bam
Hey, I found Waldo! What is my reward?
Posted: Fri Apr 27, 2018 8:16 am
by Speedr8
was clear :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
Posted: Fri Apr 27, 2018 9:04 am
by FaisalJ
bam_bam wrote:Hey, I found Waldo! What is my reward?
Bam, mate. That’s Wally.
Posted: Fri Apr 27, 2018 9:12 am
by bam_bam
You can search for Wally's, I'll look for Waldo's.
All depends where you grew up... ha! Like I ever grew up.
Posted: Sat Apr 28, 2018 6:42 am
by Speedr8
Despite Wally a sharp device :bigblink:
Regards Tom :thumb:
Posted: Sat Apr 28, 2018 9:04 am
by Brooner
Looking forward to seeing what you can do with the V10 it should be mental if your V8 is anything to go by
And its defiantly Waldo :mrgreen:
Posted: Sun Jul 22, 2018 4:39 pm
by Speedr8
Hi
Something new bought.
Tom
Posted: Mon Jul 23, 2018 6:57 am
by Covkiller
Good move strapping the battery down; "Antigravity" :bigblink:
Posted: Mon Jul 23, 2018 9:38 am
by classba
Tom... you should had also bought their dedicated mount :)
