light and strong Audi R8 V8
Models: V10 plus, GT, GT Spyder, V8 Limited Edition, Exclusive Selection Edition, China Edition and LMX
4.2 V8 32v Naturally Aspirated - 414 bhp (2007-2011) - 424 bhp (2012-2014)
5.2 V10 40v Naturally Aspirated - 518 bhp (2012-2014) - 542 bhp (Plus 2012-2014) - 562 bhp (LMX 2012-2014)
5.2 V10 40v Naturally Aspirated - 533 bhp (2015-)
5.2 V10 40v Naturally Aspirated - 602 bhp (Plus 2015-)
classba
Re: light and strong Audi R8 V8
Post by classba » Sat Feb 03, 2018 5:02 pm
Speedr8 wrote:
Sat Feb 03, 2018 3:57 pm
Hi @classba
If you have the knowledge that the R8 V8 injectors make more throughput than the V10, then you take these.
If the high-pressure pumps of the V10 Gen1 are too weak, then you take the amplified version of the free market.
Tom
Tom, I think you will still struggle even with your say that the V8 injectors are larger/ flows more. The Gen-2 have double the amount of injectors compared to the Gen-1 and the most you can get out of them with an ECU map is around 650ps ( NOT BHP) maximum.
Anyway, best of luck again and hope you will hit your target. :beerchug:
Speedr8
Post by Speedr8 » Sun Feb 04, 2018 8:57 am
Hi @classba
The problem with the V10 is not the fuel supply, but the necessary fresh air in the cylinder for it !
A good basis is the 610HP intake manifold and 90 degrees rotated TB for good uniform distribution of air to all cylinders per cylinder bank.
The smaller exhaust valves of the narrower contoured 610 engine in conjunction with the 610HP camshafts complete the package.
But perfect cylinder head machining is a prerequisite for this.
So do not worry, that will work.
It was also said that no 500hp in the V8 engine are possible and, I've done it.
Tom
Brooner
Post by Brooner » Sun Feb 04, 2018 9:24 am
look forward to seeing the new V10 project unfold
Speedr8
Post by Speedr8 » Mon Feb 12, 2018 7:46 am
Hi
The R8 was indeed already finished for the start of the season in 2018 but not since yesterday.
Reason are larger exhaust flaps with larger cross section.
The built-in flaps in my exhaust system have an inner diameter of 51mm with a tube inner diameter of 59mm.
The new flaps have an inside diameter of 59mm and have no edges.
The exhaust gas can thus flow through unhindered and more engine power is generated.
New flaps
The still installed flaps
Tom
Speedr8
Post by Speedr8 » Thu Mar 29, 2018 9:27 am
Hi
Visually, something was missing on the front and I was not sure what that looks like.
But the decision was good to mount winglets.
Tom
Speedr8
Post by Speedr8 » Fri Apr 27, 2018 6:17 am
So girls
As value preservation and the look because of, there was a mint R8 GT tailgate.
Positive side effect, the tailgate weighs 2.8Kg less than my modified series tailgate.
The weights in detail. Series 23,8Kg, GT 13,1 Kg, my modified 15,9Kg.
In addition, I could not resist and had to buy a set of carbon R8 GT mirror.
Less weight 0.53 kg compared to the facelift mirror.
Tom
Post by bam_bam » Fri Apr 27, 2018 7:11 am
Hey, I found Waldo! What is my reward?
Speedr8
Post by Speedr8 » Fri Apr 27, 2018 8:16 am
was clear :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
FaisalJ
Post by FaisalJ » Fri Apr 27, 2018 9:04 am
bam_bam wrote:Hey, I found Waldo! What is my reward?
Bam, mate. That’s Wally.
2007 RS4 B7 Avant
Post by bam_bam » Fri Apr 27, 2018 9:12 am
You can search for Wally's, I'll look for Waldo's.
All depends where you grew up... ha! Like I ever grew up.
Speedr8
Post by Speedr8 » Sat Apr 28, 2018 6:42 am
Despite Wally a sharp device :bigblink:
Regards Tom :thumb:
Brooner
Post by Brooner » Sat Apr 28, 2018 9:04 am
Looking forward to seeing what you can do with the V10 it should be mental if your V8 is anything to go by
And its defiantly Waldo :mrgreen:
Speedr8
Post by Speedr8 » Sun Jul 22, 2018 4:39 pm
Hi
Something new bought.
Tom
Covkiller
Post by Covkiller » Mon Jul 23, 2018 6:57 am
Good move strapping the battery down; "Antigravity" :bigblink:
RS4 B7, Mugello Blue, K&W V3 & HR ARBs, set up by Centre Gravity, Milltek Valved Non Res & cat bypass pipes, BMC air filter, braided hoses, DOT 5.1, Terraclean, MRC Full Carbon Clean, MRC remap 448PS 477NM, 20" S7 alloys with 4mm spacers & Hawke spigots 66.6 > 57.1, AP Racing front discs.
classba
Post by classba » Mon Jul 23, 2018 9:38 am
Tom... you should had also bought their dedicated mount :)
Return to “R8 Coupé / Spyder (Typ 42) 2007-”
Users browsing this forum: No registered users and 3 guests
