DRC Leaking - Can The Shock Be Repaired?
Hi All,
Replaced the front disks and pads tonight and noticed my drivers side rear shock leaking (Pics below)
I havnt had the telltail clunking and think i have caught the leak early as it wasnt there a month ago (hasnt fully soalked the wishbone yet)
Question is if i remove the shock can the top seal that i assume is leaking be repaired/replaced or is it definateley new shock time?
Any advice would be much appreciated
P.S the car turned 5 before Christmas so i assume i cant go down the warantee route?
Thanks, Steve
Thanks, Steve
Now - Audi SQ5 Plus and planning future A3 3.2 DSG Turbo Project
Re: DRC Leaking - Can The Shock Be Repaired?
the only way to know how bad is to clean it off and pressurize it to see if or how bad it leaks
Grizz (a forum vendor) has the set-up to do that
You probably may as well replace the shock if you're going to drain then repressurise the system. IIRC a new shock is £180 + VAT
Hi , We can supply & fit a new shock along with a new hose and re pressure the system in house .
Grizz
Grizz
Unit 20
0151 3366888
0151 3366888
I am in south Wales so not to close to you grizz
I have a mate who runs a garage who i would I be able to get the shock from trade price (i thought they were a lot more than £180)
Could i then partially fill the shock then fit it myself - is this possible?
Then i take it if the above is possible i would need to take it to a specialist like youself grizz to re-pressurise?
Am I correct.
(sorry for the questions but I have full use of ramps and a garage and after just replacing my front disks and pads i am trying to do this repair as cheaply as possible)
Cheers, steve
Am I correct.
Cheers, steve
- voyager162
- 1st Gear
easy enough to fit, but you will need to get system pressurised, by either your local dealer or someone like unit 20, trouble is you shouldnt really be driving it with no pressure in the system.
Would it do damage if I opened the system to remove struts then refitted them to drive to get the system charged?
- 2nd Gear
All audi Garages have the charging equipment , they probably charge like a wounded buffalo however . The car can drive with out the replacement shock being charged but only to get it to somewhere to refill . the shock cannot function correctly with out the Gas pressure , so caution when driving as its not safe .
The problem you have is very common and likely to occur on other shocks in the car over time , the DRC pipes also corrode and they are costly to replace . Would be worth looking at just replacing the shocks with a quality replacement kit , Message me for the details . you can search on this forum for KONI replacement dampers ?? might be worth looking at because its very cost evective long term .
Audi charged me £220 inc VAT for a full system replenishment and recharge, so it’s perhaps not as bad as some are making out. I think this even included the hydraulic oil itself.
My system functions perfectly. But I need to open the system to fit new springs.
On a C6? Was concerned about damaging a line. Didn't look like the strut would come down far enough. Could you share your method?
Apologies B7 .
It is quite expensive though if you have to add this to the cost of replacing a damper or any part of the system every time .Pistolpete2543 wrote: ↑Tue Nov 06, 2018 8:58 amAudi charged me £220 inc VAT for a full system replenishment and recharge, so it’s perhaps not as bad as some are making out. I think this even included the hydraulic oil itself.
Depends how much you value originality of your B7 RS4, renowned as one of the greatest drivers Audi’s ever made.neil_f wrote: ↑Wed Nov 07, 2018 11:48 pmIt is quite expensive though if you have to add this to the cost of replacing a damper or any part of the system every time .Pistolpete2543 wrote: ↑Tue Nov 06, 2018 8:58 amAudi charged me £220 inc VAT for a full system replenishment and recharge, so it’s perhaps not as bad as some are making out. I think this even included the hydraulic oil itself.
Users browsing this forum: Google Adsense [Bot] and 409 guests
