Page 1 of 3
An LED number plate light that works?
Posted: Thu Jun 21, 2012 6:45 pm
by mark758
Re: An LED number plate light that works?
Posted: Thu Jun 21, 2012 10:10 pm
by RS6chris!
I bought these...
http://www.ebay.co.uk/itm/Audi-A4-B6-S4 ... 3370110699
Had them in my C6 RS6 now for two months....very good quality...nice crisp light...and no errors at all.
Chris.
Posted: Thu Jun 21, 2012 10:13 pm
by Gavla
I used these from Ebay and they fitted okay no problems. Think look the same make as above.
http://www.ebay.co.uk/itm/270695994121? ... 1423.l2649
Also check out these if you want interior LEDs
http://www.ebay.co.uk/itm/280696913699? ... 1423.l2649
Posted: Fri Jun 22, 2012 12:07 am
by mark758
Many Thanks Gents
LED interior light set ordered
Posted: Fri Jun 29, 2012 1:40 pm
by voyager162
i ordered those led number plate lights from ebay fitted today and they throw up an error
pain to bag em up an send them back so will prob fit the correct resistor to get them working, but just a heads up if anyone was thinking of ordering.
Posted: Fri Jun 29, 2012 2:11 pm
by Gavla
That's weird - mine was okay? They also say no-canbus error - mmm a bit of a pain in the a&se.
Posted: Fri Jun 29, 2012 3:04 pm
by C5ARK_RS4
Which ones did you order from ebay voyager - the ones RS6Chris bought (which are just bulbs) or the ones Gavla bought (which are the complete unit)?
Posted: Fri Jun 29, 2012 5:02 pm
by RS6chris!
As i said above mine are spot on....in a C6 RS6.
Dont know if the B7 RS4 has something different on the electrical side of things??
Bearing in mind my rear lights are OEM LED so dont know if this would have an effect on number plate bulbs??
Posted: Fri Jun 29, 2012 5:48 pm
by C5ARK_RS4
It seems that these led bulbs work on some and not others. Mikefish on here has the led complete unit bulbs from eBay (see "another led bulb thread") and they work fine on his with no errors.
Posted: Fri Jun 29, 2012 8:28 pm
by adsgreen
As i understand it There's two things - 'no can bus error' relates to an ecu method of checking for blown bulbs.
The b7 rs4 just uses a basic resistance check and isn't can bus so will show an error.
Posted: Sat Jun 30, 2012 5:10 pm
by mark758
The JDM powered units purchased are installed and work fine, no errors. I did need to fit a screw with a fractionally smaller head but used the opportunity to replace the original screws with some stainless steel ones. In fact the lamp units themselves are probably a slightly better quality than OEM!
Posted: Thu Jul 19, 2012 1:31 pm
by voyager162
if it ever stops raining i'll get out and check resistance and see if there is a huge difference.
Posted: Thu Jul 19, 2012 3:54 pm
by ArthurPE
Posted: Thu Jul 19, 2012 5:23 pm
by leadfoot
I bought the ECS tuning ones 3 months ago... and ***error***... after a call to ECS... they said to return them... with the ones you show... they claim no errors...... the quality of the ones I bought looked good.. but fit was a BITA... as i had to enlarge the screw holes...
ECS does not seem to be very good differentiating between B& RS$ and misc A4 products... as their online catalogue lists all sorts of none RS4 parts, even though you specify t he make and model up front... i
Posted: Thu Jul 19, 2012 8:19 pm
by MikeFish
I bought the exact ones that Gavla linked from eBay and have had no problems. I previously tried to change just the lamps and got errors.
