Page 1 of 7
LOBA RS4 B7 Bake disc upgrade Preproduction test discs
Posted: Tue Feb 07, 2012 10:17 am
by supersi
LOBA RS4 B7 Bake disc upgrade....Coming soon
A few key points on LOBA MOTORSPORT  B7 Brake upgrade
Bolt On Replacement no other modifications to carry out (PLUG&PLAY)
The assembly uses " Float in the Bell" Technology
float is limited to 0.2mm compared to 0.5-0.7mm float in float in the disc systems such as Alcon or less capable AP racing setup
Custom rate developed bobbin springs allow design axial and radial float whilst maintaining OEM levels of NVH
xial flow of air from behind the bearing to the centre of the disc via 48 vanes and a 17mm air gap
Optionally available with temperature sensing paint applied set to 430/560/610 degrees
Disc Rotor is by AP Racing and is cast in the UK
significant weight saving per corner
Range of pads available which we spec to your needs
Design requirements was nominally 10-12 track laps at competitive driver speeds, surpassed in initial testing by professional drivers
All components from rotors to washers are available separately through LOBA,  this is truly a disc assembly for life, whole life cost is lower than OEM especially for tracked vehicles
Re: LOBA RS4 B7 Bake disc upgrade Preproduction test discs
Posted: Tue Feb 07, 2012 10:41 am
by sonny
As already mentioned over on SRS these do look the bomb and will be keeping an eye on development.
Posted: Tue Feb 07, 2012 10:56 am
by P_G
OOOoooooo, me likely. Will you be doing rears as well as fronts? And do you have indicative prices? One last question, you say significant weight savings, what is 'significant'?
very keen to know more..... :thumbs:
Posted: Tue Feb 07, 2012 10:58 am
by Jules
Liking them :thumbs:
Posted: Tue Feb 07, 2012 11:07 am
by supersi
Heat management by Design allows us to use thinner disc so there for less mass saving estimated 3.5-4kg weight per corner, Rotor size is 362mm it eliminates the lip that is created with 365mm OEM disc, thickness is 32mm instead of 34mm
Disc Bell CNC machined by a supplier to race teams at the pinnacle of Motorsport
have been and looking at upgraded rears as i too want myself, but is very limited because of caliper and OEM being very thin and not vented
price yet to be confirmed
Posted: Tue Feb 07, 2012 12:21 pm
by klauster
group buy? :)
Posted: Tue Feb 07, 2012 1:05 pm
by adsgreen
14-16 kg of unsprung mass is huge!
I like!
Posted: Tue Feb 07, 2012 1:20 pm
by supersi
klauster wrote:group buy? :)
yes by all means could do a rs246 group buy :) something we can look into if of interest
check out our facebook page for more pics and updates :thumbs:
Posted: Tue Feb 07, 2012 2:55 pm
by P_G
adsgreen wrote:14-16 kg of unsprung mass is huge!
I like!
It'll be 7-8 kgs since theye are only talking about fronts but still not to be sniffed at! :beerchug:
Part of that though surely is increased central vanes and being a 32mm width disc rather than 34mm so less steel involved and it would be interesting to find out what the thickness of the disc surfaces are and what minimum tolerance is (30mm?) to have a guestimate at durability. But if they are what they say they are and around £500-600 per pair then they are definitely on the shopping list with the better cross drilled pattern.
by P_G
si, when is projected production date?
Posted: Tue Feb 07, 2012 3:24 pm
by edge
Any ideas on when the actual confirmed cost and first production set will be for sale?
Posted: Tue Feb 07, 2012 3:32 pm
by DavidRS4
They look sexual, interested to see how the rest of the development goes and how much they retail at.
Posted: Tue Feb 07, 2012 4:02 pm
by supersi
edge wrote:Any ideas on when the actual confirmed cost and first production set will be for sale?
not long for at all for launch within this month, bobbin and bell system is tested and proven fantastic by friends and pro drivers and are being used now and have been for some time .. just want to try test a set on my car to be 100% on pad spec and feel and so on, price we have a idea just waiting on final costs to give a RRP and demand will help us get prices lower.
Posted: Tue Feb 07, 2012 4:03 pm
by supersi
DavidRS4 wrote:They look sexual, interested to see how the rest of the development goes and how much they retail at.
i looking fwd to this too 8)
Posted: Tue Feb 07, 2012 4:13 pm
by P_G
Si, I won't be tracking mine so will it be OK to use EBC YS's on these discs for road use?
