Driving the 4.2 efficiently while still having fun
Posted: Sat Jan 28, 2012 9:23 pm
First of all my excuse for discussing economy on this forum is that my previous car was an A3 1.9 TDI 110 where everything was about economy. Plus I’m not exactly swimming in money like some folks are.
For those times when you just want to take it easy e.g. to enjoy the views, or when you have people in the car that moan about going too fast, or you’re just wedged in a row of traffic, or your missus is banging on about an aching neck, I’d like to share what I have figured out which reduces fuel usage. I regularly average close to 30MPG while still having regular bursts of fun up to the red line. Having your cake and eating it appeals to me.
My rule #1 is simply adjust your driving so you do not use the brakes. Think about what is happening ahead e.g. in normal town driving conditions don’t tare up to red lights and junctions. Obvious stuff but so many people do just that! Judging speed and distance stop is a game to me. Every time you touch the brake pedal it costs you money. Keep a good distance between you and the car in front so when people slow to turn off at junctions you just lift off the accelerator and do not need to use the brakes.
Second is if you do need to use the brakes, use the engine as a preference by downshifting a few gears. Downshift again when the revs drop to ~1500RPM. I notice my car lurch slightly when in a low gear with my foot off the gas and the revs drop to 1500. I presume the ECU begins injecting fuel at this point as the revs are dropping towards idle. During a down shift I have perfected the sequence of blipping the accelerator while the clutch is down, selecting a lower gear and catching the revs as they fall by lifting the clutch when the engine speed matches the speed of the gearbox in the lower gear. With the right technique you can drop from 6th to 3rd with no noticeable lurch of the car (however in synchrony with a barrier of V8 wine which occurs). Also good technique to drop 4 cogs for a lively overtake.
When accelerating gently i.e. cars in front, change up a gear around 1500RPM. Get into 6th at 30. Think of the pistons as 8 cans of baked beans. If you hold a baked bean can and shake it up and down slowly it’s not very tiring. Shake it up and down as fast as you can and it soon makes your arm ache. The same physics are going on in the engine so the slower it turns then the less power is required to turn it.
Next is that I found it makes the MPG rocket when I use neutral when going downhill or any other conditions when you don’t need to accelerate. If my foot’s just on the accelerator enough to keep the engine from slowing the car down, I select neutral. Yes fuel will be used to keep the engine turning at idle speed, but much less than to keep the engine turning at ~ 3000RPM e.g. when travelling down a relatively steep gradient without any need for engine power. I haven’t found any problems with stability of the car when coasting in neutral. Just be ready on the clutch and gear stick to engage quickly should you need power to manoeuvre. This works on motorways as well.
When I wind it up I generally make sure I don’t have to subsequently slap the brakes on.
Using all of the above I recently did a 160 mile trip through the middle of Wales and averaged 32MPG thanks to all of the downhill coasting opportunities.
Then there’s times when all of the above goes out of the window and low 20 MPG results with a big grin!
Just a few ideas for when you feel like driving efficiently. That is all.
