Which would be the best to go for?
The NGK's at £74.50
http://www.ebay.co.uk/itm/Spark-Plugs-S ... 4842e0e405
or the oem At £89.99 + postage
http://www.ebay.co.uk/itm/Genuine-Audi- ... 5d2c59477b
I'm not concerned about the price difference but if the cheaper ones are just as good then i'll go for those.
Are the oem ones also platinum tipped or iridium?
cheers
Spark Plugs again
Spark Plugs again
TTS RS4 -amazing machine,
Previous:
Previous:
Re: Spark Plugs again
genuine audi plugs are ngk so buy the cheapest,also look at europarts for ngk they might be cheaperwrekka wrote:Which would be the best to go for?
The NGK's at £74.50
cheers
i went for the bosch and in my opinion think they perform better than the ngk that was in
The Bosch are reputedly better plugs, they just had an issue a couple of years ago with a bad batch with brittle cores which is why Audi then went NGK but I have Bosch in mine IIRC.
NGK use fine wire for there plugs and Bosch just came out with a fine wire spark plug which is why Audi and BMW etc use NGK plugs.
Boschs new fine wire plug:
http://www.boschautoparts.com/sparkplug ... idium.aspx
So if your car has NGK use NGK unless your country has the new Bosch plugs available.
Users browsing this forum: No registered users and 169 guests
