De-coke Done
Posted: Sat Oct 08, 2011 11:47 pm
Car now running so much better, took it out for a spin loads more low down torque and when it hit 5500 rpm i started laughing, it goes nuts, i always knew it was down on power
Sounds like you need to check for a vacuum leak first DaveDave_M wrote:Looking good. I plan on doing this in due course - mine's currently done 47k miles and has definitely lost its 5500rpm kick. Did the DIP3 dissolve the deposits on its own or did it need scrubbing as well - in which case what did you use to scrub it?
Also, what did you use to get the DIP3 out of the inlet tract to ensure nome of the DIP3 or deposits subsequently dropped into a cylinder?
It took a good two daysguffy wrote:Looks good to me.
How long did it take you?
I used two cans DIP3 that i had spare, and two cans of whynns carb cleaner, and it took a hell of alot of elbow grease, you have to get the soft carbon off first and then the hard carbon!!P_G wrote:Good job, did you use DIP3 aerosol and then wipe or was it the petrol additive you used?
The DIP 3 and carb cleaner helps alot to dissolve it but it does take alot of scrubbing and scrapingDave_M wrote:Looking good. I plan on doing this in due course - mine's currently done 47k miles and has definitely lost its 5500rpm kick. Did the DIP3 dissolve the deposits on its own or did it need scrubbing as well - in which case what did you use to scrub it?
I used an old henry hover and reduced the pipe size to get into the inlet port but you must make sure the valves are shut before scrubing or chapping any carbon off, i made sure they were shut by spraying some DIP3 in and leaving it for a bit, as soon as i was confident it was not draining away i knew the valves were closed and then procceded to clean, its all this that takes the time as the last thing you want is bits of carbon flying around in the cylindersDave_M wrote:Looking good. I plan on doing this in due course - mine's currently done 47k miles and has definitely lost its 5500rpm kick. Did the DIP3 dissolve the deposits on its own or did it need scrubbing as well - in which case what did you use to scrub it?
I'm considering having a go myself. I have a good range of tools, any specials required?HEo2TEC wrote:It took a good two daysguffy wrote:Looks good to me.
Interested to know how coking affects the 'kick', i though that was provided via the power flap?Dave_M wrote: mine's currently done 47k miles and has definitely lost its 5500rpm kick.
