Headlight washer gets stuck after use
Posted: Thu May 26, 2011 12:42 am
Richie Garcia here... My Headlight washer gets stuck after use ..... just wanted to ask if anyone had the same problem... The passenger side gets stuck in the extended position , I have done some research on some other audi forums usually it's caused by snow / dirt or misaligned bumpers that might have hit one of the high pressure hoses or spring mechanism .... As suggested by other forums I filled the tank with water and tried to reset by running water thru the system... Sadly it Still gets stuck on its fully extended position ;( I tried pushing it back manually.. it feels like something is stopping it when I put a little more force water spurts out from the nozzle as it slowly retracts back in... When I do the process again it gets goes out normally but gets stuck again before going back in....
Any thoughts?
Any thoughts?
