Misfire
Posted: Sun May 01, 2011 1:23 pm
by Guernsey70
Turned the S button on in 2nd gear, gave it some juice and at 5.5 rpm she started to misfire. Only happens in 2nd gear the first time the S button is switched on and then it clears.
Any ideas what this could be or why it happens?
G70
Re: Misfire
Posted: Sun May 01, 2011 9:28 pm
by adsgreen
unlikely to be related to the sport button - all it does is open exhaust flaps and change the throttle mapping for the accelerator pedal input.
Re: Misfire
Posted: Mon May 02, 2011 4:44 pm
by RS4_Nick
Could be the over-sensitive traction control if you're belting into the gears too hard.
Try again with traction control off using the same driving style. As previously suggested this should not be related to sport button.
Nick
Re: Misfire
Posted: Mon May 02, 2011 5:26 pm
by sonny
IIRC if it is misfiring the EML will flash.
Re: Misfire
Posted: Mon May 02, 2011 7:14 pm
by Guernsey70
Thanks, will try turning off the traction control.
G70
Re: Misfire
Posted: Mon May 02, 2011 11:36 pm
by adsgreen
sonny wrote:IIRC if it is misfiring the EML will flash.
Depends - it won't trip on one or two misfires. There needs to be a set amount over a given timeframe for it to trip the light.
Re: Misfire
Posted: Tue May 03, 2011 8:53 am
by sonny
adsgreen wrote:sonny wrote:IIRC if it is misfiring the EML will flash.
Makes sense.
