Page 1 of 2
retrofit Audi Bluetooth system
Posted: Tue Apr 12, 2011 11:08 pm
by andymc
Hi all ...
So I've read through a few posts on bluetooth here and came to the conclusion that I could get a standard audi bluetooth system retrofitted?!
However, I popped into Camberley Audi service centre today to be told this isn't possible. It was factory-fit only.
My questions are:
- Are camberley Audi correct and I cannot get the standard system retrofitted?
- If they are right - what options do I have ?
- If they are wrong - which Audi dealership has done this successfully?
thank you ...
Re: retrofit Audi Bluetooth system
Posted: Tue Apr 12, 2011 11:16 pm
by Rick_RS4
wouldnt get it done at the dealer if they could do it anyway, far to expensive, theres a couple of places mentioned on this site if you do a search that will retro fit bluetooth like OEM
Posted: Wed Apr 13, 2011 10:12 am
by PhilT
I've been thinking about the same thing (For a C5 RS6), but the price I have in my head for the parts is about £500. There have been posts recently regarding the Kenwood double DIN units, and once you add the nav disk (£200) to the bluetooth (£500) it seems to me that you might be better off with an aftermarket unit?
http://www.kenwood-electronics.co.uk/pr ... DNX9260BT/
Posted: Wed Apr 13, 2011 11:25 am
by Dave_M
I had a Kenwood double din satnav and handsfree setup in my previous car and it was very good - way better than the Audi setup. Also had speed camera alerts on it. The only thing you'd lose is the directions appearing in the DIS display.
Depends if you're bothered about keeping it OEM.
Dave
Posted: Wed Apr 13, 2011 5:04 pm
by PetrolDave
andymc wrote:to be told this isn't possible. It was factory-fit only.
Usual dealer reply - what they mean is that Audi do not supply a retrofit kit.
Yes it IS 100% possible, I've done at least half a dozen Audi OE BT retrofits.
You can get a complete kit of everything you need from Kufatec.
Installing it takes about 1 - 1.5 hours, but you DO need VCDS (VAG-COM) to recode the instruments, sat nav (or radio) and the BT module itself.
Posted: Wed Apr 13, 2011 6:12 pm
by sonny
Yep as Dave says, I had Craigyb do mine, his on the forum.
http://www.tclsatnav.com/index_002.htm
Posted: Wed Apr 13, 2011 6:35 pm
by Adam
I had HazzyDayz do mine with OEM parts, works very well.
They are national and travel to you whereas craigyb is based up in Manchester so no good for me
http://www.vw.cruise.com
Posted: Wed Apr 13, 2011 6:55 pm
by charlesdash
Ditto the Kufatec system, cost was £225 I think and as well as the standard features of the Audi system (which it behaves exactly the same as for phone features,) it can also stream music from your phone through Bluetooth, if your phone has the functionality to do so (i-phone 4, or most smart phones). Although the quality of the streamed music falls short of the fully installed and wired player, it does leave you free to still use the CD player and card reader etc. a very elegant solution!
Posted: Wed Apr 13, 2011 7:48 pm
by PetrolDave
charlesdash wrote:Ditto the Kufatec system, cost was £225 I think and as well as the standard features of the Audi system (which it behaves exactly the same as for phone features,) it can also stream music from your phone through Bluetooth, if your phone has the functionality to do so (i-phone 4, or most smart phones). Although the quality of the streamed music falls short of the fully installed and wired player, it does leave you free to still use the CD player and card reader etc. a very elegant solution!
You're talking about the third-party Fiscon BT module - Kufatec also sell the OE Audi module, so you have the choice.
IMHO the streaming audio on the Fiscon is a complete joke - the connection between the BT module and the RNS-E is low bandwidth (300-3300Hz) MONO intended for voice only, so for music it's rubbish (unless you like music that sounds like it's being played through a baked bean can?).
by amanda1
+1 Craigb Has done mine in a c5 with oem audi parts and I run a pie phone 3gs ..........works great
Ohhhh my dealer also told me it couldn't be retrofitted!!!!
Posted: Wed Apr 13, 2011 7:51 pm
by PetrolDave
Adam wrote:whereas craigyb is based up in Manchester so no good for me
craigyb travels around the country fitting...
I'd rather have craigyb do it than HazzyDayz - they get mixed feedback but craigyb gets only good feedback.
Posted: Thu Apr 14, 2011 6:15 am
by sonny
PetrolDave wrote:Adam wrote:whereas craigyb is based up in Manchester so no good for me
Agree, he fitted mine in London. But this was a few years ago now.
Posted: Thu Apr 14, 2011 8:20 am
by jasonpaul
just had fitted a parrot 9200i this is very good and it was fitted very well it has a colour screen and Ipod fitting.
Posted: Thu Apr 14, 2011 12:37 pm
by klauster
whats the cost for fitting it?
Posted: Thu Apr 14, 2011 3:58 pm
by PetrolDave
jasonpaul wrote:just had fitted a parrot 9200i this is very good and it was fitted very well it has a colour screen and Ipod fitting.
But it's not OE and IMHO the extra screen kinda spoils the look of the dash.
