Hi,
Brakes on my 2007 avant (26k miles) are not that brilliant and have bit of vibration.
I was thinking of getting them skimmed considering the cost of new ones.
Any advice on this and what pads to use front and rear ?
Thanks.
Brakes
Re: Brakes
You'll need to work out if it front or rear first. Rears can be skimmed on hub, fronts unless the skimmer in question is good should be done off the car as they are floating. Replacement pads, either Ferrodo DS2500 or EBC Yellowstuffs, both produce a lot less brake dust than OEM Pagid's and the latter have wear sensors in the fronts like OEM wheras the Ferrodo's do not.
Re: Brakes
Thanks,
I was going to take the 4 of them off and get them done that way.
If i did have to replace them where are the best deals to be had ?
Re: Brakes
Couple of traders on here who I am sure will be along shortly; I usually pick mine up off fleabay new or used.
Users browsing this forum: Google Adsense [Bot], Zyox and 438 guests
