Page 1 of 3
Time to check your auxiliary radiators...
Posted: Tue Jan 11, 2011 9:52 pm
by neckarsulm
..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
(the crud retains moisture and eventually causes corrosion of the rads)
Re: Time to check your auxiliary radiators...
Posted: Tue Jan 11, 2011 9:57 pm
by wrekka
neckarsulm wrote:..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
Yep, mine are slowly dripping now, been quoted off Audi £610 to sort including labour. Will see if my 3rd party warranty will cover it, mmm...
Posted: Tue Jan 11, 2011 10:02 pm
by MB2
wrekka wrote:neckarsulm wrote:..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
Is that to replace the pair ? I keep mine clean but am beginning to have my suspicions about them...
Posted: Tue Jan 11, 2011 10:08 pm
by wrekka
MB2 wrote:wrekka wrote:neckarsulm wrote:..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
Yes to replace the pair
RE: Re: Time to check your auxiliary radiators...
Posted: Tue Jan 11, 2011 10:41 pm
by Ice_Coffee
Mrc will probably fit it for less, and you can probably get genuine replacement rads from gsf or similar for a lot less than audi money
Posted: Tue Jan 11, 2011 11:14 pm
by lengster1
Mrc go 1 better they get rid of the o/s one and that pesky airbox flap aswell lol
Posted: Wed Jan 12, 2011 1:01 am
by chrisd31
sorry to sound dim but where are these rads just so i can have a quick look at mine?
Chris
Posted: Wed Jan 12, 2011 9:01 am
by neckarsulm
in the bumper there are 3 grilles, behind the 2 outer ones are the aux rads. You may need a torch.
Posted: Wed Jan 12, 2011 10:28 am
by klauster
had mine replaced under warranty, apparantly its a common problem on the RS4 so the dealer said
Posted: Wed Jan 12, 2011 10:33 am
by wolfgang
This was a common problem with Porsches too. Are the leaves removable without putting the car up on a ramp?
Posted: Wed Jan 12, 2011 11:41 am
by neckarsulm
can't see why not
Re: RE: Re: Time to check your auxiliary radiators...
Posted: Wed Jan 12, 2011 11:53 am
by caldy
lengster1 wrote:Mrc go 1 better they get rid of the o/s one and that pesky airbox flap aswell lol
Not so sure they do remove the o/s aux. rad. Do they not remove the vacuum pump and route a length of piping direct to the bottom feed of the standard air box via the removed flap opening?
Posted: Wed Jan 12, 2011 7:26 pm
by PetrolDave
klauster wrote:had mine replaced under warranty, apparantly its a common problem on the RS4 so the dealer said
It's a common problem on the B6/B7 S4 as well. In fact it was so common on the B6 S4 that they redesigned this area on the B7, but it still seems to be a problem area (I had my OS one replaced in 2009).
Posted: Wed Jan 12, 2011 7:37 pm
by neckarsulm
Problem with RS4 one is that while the honeycombe prevents less debris getting down there compared to single slat of B7 S4, its much harder to see
Posted: Wed Jan 12, 2011 7:50 pm
by RS6chris!
The honeycomb grills just pull out with a good tug...very easy..clean out...then they just clip back on...simples!!
I clean mine out every month...all kinds of debris gets in there!!!
