Page 1 of 5
Suggestions for keeping your RS4 in tip-top form
Posted: Thu Dec 02, 2010 10:49 am
by wolfgang
I'm just trying to build a list of tips on keeping your RS4 in tip-top condition. Having spent many hours on the forum, i've got the following so far:
1. Use decent fuel (like Shell V-Power)
2. Get the wheels aligned
3. Switch to fixed service intervals
4. Get the latest software update (SW0090)
5. Use decent tyres (eg. Goodyear F1 Eagle Asymmetrics)
Any others?
RE: Suggestions for keeping your RS4 in tip-top form
Posted: Thu Dec 02, 2010 11:19 am
by ShaneyB
Rubber mats in the winter.
Posted: Thu Dec 02, 2010 11:24 am
by P_G
Drive it as an every day car. Let it warm up gently to full engine temperature and then take it for long runs using the full rev range including some motorway driving. And don't be afraid to give the brakes some punishment either every now and again.
Posted: Thu Dec 02, 2010 11:29 am
by approved
get it up to temp.
and abuse it, regularly
Posted: Thu Dec 02, 2010 12:24 pm
by rs4nick
Are supermarket super plus fuels (e.g. Tesco Momentum 99 & Sainsburys Super Plus) considered decent fuel? Any views as currently tends to be supermarket fuel that I use but always super plus and not std unleaded. Or should I steer clear?
Posted: Thu Dec 02, 2010 12:41 pm
by andre3k
I read an article some time ago and the consensus was Tesco 99 (Momentum) was superior to the Shell equivalent. Can't remember what the exact criteria was for measurement (increase in hp, fuel efficiency, or something else)
Posted: Thu Dec 02, 2010 1:11 pm
by wolfgang
Doesn't Tesco 99 have a (relatively) high ethanol content to get it to 99-RON classification?
Posted: Thu Dec 02, 2010 1:15 pm
by HYFR
I used Tesco 99 for 10k in my B7 ... Brilliant
The B7 LOVES to rev, so ring its neck out when warm
Wash and wax regularly, espcially in salty weather
Keep an eye on oil as some love to drink it
Change oil every 5k if possible ... Should only cost £150
Posted: Thu Dec 02, 2010 1:17 pm
by wolfgang
Check and set the correct tyre pressures regularly.
Posted: Thu Dec 02, 2010 4:11 pm
by neckarsulm
Halve the service intervals for oil, plugs and air filter
Clay bar the paint each summer
Lubricate exhaust flap linkages
If you have buckets, chose carefully how you get in and out of the car
Posted: Thu Dec 02, 2010 4:25 pm
by wellzieRS4
I would use shell remember when dirty supermarket fuels fucked loads of cars up couple of years ago
Posted: Thu Dec 02, 2010 4:36 pm
by PetrolDave
Regularly take the "scenic route" home and drive it hard when you do.
Posted: Thu Dec 02, 2010 5:30 pm
by P_G
I used to use Momentum 99 all the time and it may be that just a change of fuel has perked the car up, however at present my RS prefers V-Power. Just feels throttle sharper and still returns similar mpg.
Posted: Thu Dec 02, 2010 6:16 pm
by RS6chris!
P_G wrote:I used to use Momentum 99 all the time and it may be that just a change of fuel has perked the car up, however at present my RS prefers V-Power. Just feels throttle sharper and still returns similar mpg.
Could be the cold weather P-G?? Mine goes like stink when the air temp is freezing!!
Posted: Thu Dec 02, 2010 7:04 pm
by shej
wolfgang wrote:Check and set the correct tyre pressures regularly.
What are the correct pressures on standard rims?
