My car thinks its going backwards!
Posted: Fri Nov 12, 2010 11:24 pm
by B7RSX
Hi lads.
Once the ignition is switched on the parking sensors come on automatically... and reverse lights stay on... while im travelling forward!! Lol.
Taken the bulbs out for the time being as people were freaking out behind me.
Whats this all about? Reverse switch needs replacing or something more sinister?
RE: My car thinks its going backwards!
Posted: Fri Nov 12, 2010 11:36 pm
by ArthurPE
sounds like the reverse switch
hopefully it's easy to access
Posted: Sat Nov 13, 2010 12:00 pm
by Ice_Coffee
I agree about the reverse switch, it will be in the gear box and is readily accessible on most vehicles. I would expect a bill for 1hr labour + parts. It maybe worth checking that the connector is plugged in securely although I must admit if it was not It would more likely lead to no reverse lights than constant reverse lights, but again purely dependant on how audi choose to do their vehicles.
Posted: Sat Nov 13, 2010 12:56 pm
by RS4KILLA
i had the same problem with mine but was intermittent
Posted: Wed Nov 17, 2010 6:46 pm
by ^Qwerty^
Switch or connector on the gearbox. They are 'designed' to collect water. The garage told me they re-routed my cable when it was replaced to avoid the same problem again.
Posted: Wed Nov 17, 2010 8:54 pm
by almoRS
I had this too at some point. Take out and re-seat the fuses for the lights and parking sensors.
Posted: Thu Nov 18, 2010 11:31 pm
by B7RSX
ok.. Thanks guys...
I will buy reverse switch replace that first and see if it does the trick. Will re-seat the fuses too hopefully should to the trick...
Posted: Sat Nov 20, 2010 5:08 pm
by bobbys4
How did you get on with this?
