Finally took delivery of my little beauty
Posted: Thu Oct 28, 2010 11:17 pm
by Dubel
I can barely sleep with her sitting on the driveway.
Although one question, took her for a drive earlier and didn't really notice any real power difference after 5K rpm. This is probably a stupid question, how noticeable is this really.
Should it smack you in the face?
RE: Finally took delivery of my little beauty
Posted: Thu Oct 28, 2010 11:39 pm
by drbru
congrats mate and welcome
I would say you can notice it but it is not a smack in the face....I would describe it as an extra search but you can def feel it
Posted: Thu Oct 28, 2010 11:44 pm
by Pie
Its more noticeable in 2nd or 3rd.
Posted: Thu Oct 28, 2010 11:51 pm
by drbru
just read that back!!
extra surge I meant to say!
Posted: Fri Oct 29, 2010 2:37 am
by irvind
I'm a relatively new owner, but in my experience I noticed little or no surge until I got a replacement air filter at MRC last week. Even then, it's quite a subtle kick, not like a turbo, but it just keeps going and going....
Posted: Fri Oct 29, 2010 5:18 am
by scaghead
i would say subtle kick probably best describes it.....good luck with the motor fella
Posted: Fri Oct 29, 2010 9:10 am
by Steve_C
Yes, as extra surge sums it up well. Similar (but slightly less) to the surge you get in a Honda Type R with VTEC but nothing like as much as a turbo kick.
Posted: Fri Oct 29, 2010 9:30 am
by Doug_S2
There are 2 things you are feeling - in the 1st 3 gears you do not getting full throttle (even though your foot is on the floor) until you hit 5000-5500rpm. In 4th to 6th gears you have WOT through the revs but at 5000 you get the cams changing and this gives you a rise in torque and another 'kick'. If you are used to turbo cars you would not call it a kick!
Posted: Fri Oct 29, 2010 9:05 pm
by S4Player
Irvined did you get a look at my car while you were at Mrc?
Re: RE: Finally took delivery of my little beauty
Posted: Fri Oct 29, 2010 10:28 pm
by mark758
Doug_S2 wrote:There are 2 things you are feeling - in the 1st 3 gears you do not getting full throttle (even though your foot is on the floor) until you hit 5000-5500rpm. In 4th to 6th gears you have WOT through the revs but at 5000 you get the cams changing and this gives you a rise in torque and another 'kick'. If you are used to turbo cars you would not call it a kick!
Great information Doug thanks!
"100 things you didn't know about the B7 RS4" by Doug@MRC.....I'd buy it! :)
Posted: Mon Nov 01, 2010 1:23 pm
by DuncS3
Good info - can we clarify - if you feel the kick in 1st to 3rd, which is WOT (In my car I definitely feel that) - is that then, not a fair indication/test that the flap/vacuum is working as it should be but rather you need to test in 4th to 6th to determine if it is working?
Because i have always felt the 'kick' at 5.5k rpm, at least in 1st to 3rd I assumed my airbox flap/vacuum system is working fine.
sorry fairly new owner if the question is too obvious
Dunc
RE: Re: RE: Finally took delivery of my little beauty
Posted: Mon Nov 01, 2010 1:30 pm
by Doug_S2
you need to test in 4th or above - it is not really a test of the flap - it is a test that there is a large enough vacuum leak to cause the car to run low timing.
Posted: Mon Nov 01, 2010 11:22 pm
by neckarsulm
what's the link between vacuum leak and low timing?
