Bluetooth Retro fit???
Posted: Mon Oct 11, 2010 11:22 am
by Mendy
Whats involved it retro fitting Bluetooth?I have recently bought a 2007 Sprint Blue RS4 with Sat Nav and assumed blutooth came as standard?? but obviously not.. :?
Posted: Mon Oct 11, 2010 11:40 am
by P_G
If your are retrofitting you'll want to install the microphone as well. Bluetooth module goes inbehind the glove box, microphone in the roof mounted light cluster so wire has to be fed from module up inside the A-pillar trim and across to the console behind the head lining. A 1 hour job in total, 2 if you haven't removed trim parts in the car before.
Dependent on how much you get the parts for then it is a £500 max job for someone to do it for you.
Posted: Mon Oct 11, 2010 11:42 am
by MB2
P_G wrote:If your are retrofitting you'll want to install the microphone as well. Bluetooth module goes inbehind the glove box, microphone in the roof mounted light cluster so wire has to be fed from module up inside the A-pillar trim and across to the console behind the head lining. A 1 hour job in total, 2 if you haven't removed trim parts in the car before.
Guide here -
http://www.rs246.com/index.php?name=PNp ... th+andy911
Posted: Wed Oct 13, 2010 11:21 pm
by bboy
I am look at doing the same thing too.
Can anyone advise the difference between the Audi OEM units offered on ebay and the Fiscon products. Links follow:
Audi OEM unit
http://cgi.ebay.co.uk/AUDI-Bluetooth-KI ... 4aa53d7800
Fiscon units
http://www.fiscon-mobile.eu/products/versions_audi.php
I figured that the Audi unit was the best bet but assume the Fiscon unit must offer additional features?
Posted: Thu Oct 14, 2010 8:09 am
by neckarsulm
If only the Audi one was from the UK and not Poland as then I'd go for that. I wouldn't fancy trying to sort out any aftersales issues with someone that far away and with a possible language barrier.
The Fiscon one listed here is being sold by main dealer Huntingdon Audi!
http://cgi.ebay.co.uk/FISCON-BLUETOOTH- ... 41520ea287
www.audiretrofit.com seem to be using Fiscon
Posted: Thu Oct 14, 2010 4:42 pm
by MB2
The main difference is with the Fiscon kit you have to use their mic which you locate on the headlining rather than in the interior light fitting which is why I went for the Audi kit.
Posted: Thu Oct 14, 2010 6:23 pm
by bboy
I have done a bit more research and found that one of the major differences between the two is the FISCONS ability to support A2DP.
From what I understand this allows a compatible Bluetooth phone to play music through the cars head unit. eg. you could play music from your iphone without the need for a dedicated interface.
I am waiting to get this confirmed from FISCON but if it is true I do like the sound of it.
As for the mic, I am sure I came across an article last night that showed how to fit the FISCON mic in the interior light unit the same as the OEM kit. Will try and find that.
Will update when I get some feedback from FISCON.
Posted: Thu Oct 14, 2010 8:56 pm
by MB2
bboy wrote:I have done a bit more research and found that one of the major differences between the two is the FISCONS ability to support A2DP.
Be careful as I believe the RNS-E just takes in mono via the car-kit as the interface was only designed to support speech so you may be disappointed with the sound quality...
Posted: Fri Oct 15, 2010 11:21 am
by bboy
MB2 your are spot on. Just got this back from Fiscon...
A2DP is in Mono, as it utilises the telephone input connection on the RNSE.
I use the SD slots to listen to most of my music but having music from the phone on occasion would be useful. I quess the question is what is the sound quality like in mono?
Anyone out there have Fiscon fitted and use the A2DP music streaming feature? Is the quality ok?
Posted: Sat Oct 16, 2010 8:11 pm
by neckarsulm
You can fit the Fiscon mic in the OE position
http://www.fiscon-mobile.eu/products/mic.php
Posted: Sun Oct 17, 2010 11:19 am
by PetrolDave
bboy wrote:A2DP is in Mono, as it utilises the telephone input connection on the RNSE.
If I had a £1 for everytime I've tried to tell people this...
bboy wrote:I quess the question is what is the sound quality like in mono?
IMHO it would be cr*p, you would lose all the spatial information, it would be like all the instruments and vocals were all in a big heap in the centre of the sound stage.
If you even remotely like your music then my advice is don't even think about it.
Posted: Sun Oct 17, 2010 12:04 pm
by RS4SRS
in a previous car I had the new Parrot bluetooth kit, which also allowed music to be played through system from your iphone - in mono..
Sound quality was awful and I couldnt listen to it. No depth or tone to it...
Steve
Posted: Sun Oct 17, 2010 1:51 pm
by MB2
Looking at the Fiscon site again there seems to be a 8 euro option for a mic that goes straight into the light & you can also update the firmware for new phones so looks a better choice now than when I looked into them last year
Posted: Sun Oct 17, 2010 4:53 pm
by bboy
Thanks for the feedback. I think I have been deterred from buying the Fiscon kit on the groups of bluetooth music playback now.
So apart from that it looks like it boils down to a preference for OEM or aftermarket units. From what I can tell functionality is pretty much identical but the Fiscon unit can be updated easily in the future if required.
Looking at price, the Fiscon plus unit can be bought from Fiscon.co.uk for 245 inc VAT if you use the discount code scirocco123 if anyone is interested.
