18" S8 wheel offset too much?
Posted: Sat Oct 02, 2010 1:47 am
by irvind
My tyres will need replacing fairly soon so considering sticking on some Winters.
I have a set of 18" Avus alloys from a Mk1 S8 which I believe are 8" wide, ET48. (Not at home right now to check first-hand)
Looking at the Vredesteins, the price seems to be about £45 (each) cheaper for a 235 40 18.
BUT, is this offset too much to correct with spacers?
Also of course, would be the cost of the spacers..
And what about TPMS sensors?
Too much hassle?!
RE: 18" S8 wheel offset too much?
Posted: Sat Oct 02, 2010 2:00 am
by ArthurPE
oem is ET 29, so 48 is way off
you would need a 20mm+ spacer to make them look right, (48 - 29) + 1/2 x 25.4 ~ 32 mm, and they would extend out same as oem 9x19 ET29
Posted: Sat Oct 02, 2010 10:48 am
by irvind
Ok thanks, looks like I'll be sticking with the original rims then!
Re: 18" S8 wheel offset too much?
Posted: Sat Oct 02, 2010 10:59 am
by steverobb1973
irvind wrote:....Looking at the Vredesteins, the price seems to be about £45 (each) cheaper for a 235 40 18.....
What Vredestein tyre did you get quotes for £45 each and where??
Steve
Posted: Sat Oct 02, 2010 11:03 am
by irvind
steverobb1973 wrote: What Vredestein tyre did you get quotes for £45 each and where??
Steve
£45 cheaper, not £45....
RE: Re: 18" S8 wheel offset too much?
Posted: Sat Oct 02, 2010 2:12 pm
by almoRS
Good luck trying to get winter Vredsteins I tried this week and there are none in the until next month with no date given.
Posted: Fri Oct 15, 2010 5:12 pm
by irvind
Where did you try? I just ordered some 255's from mytyres, £198 a pop.
I'd already rang my usual guy in Glasgow who also had no problem sourcing them, albeit quite a bit more expensive...
