Page 1 of 2
Question about Auto-boot function
Posted: Fri Sep 17, 2010 12:45 pm
by sonny
When one operates the boot button from the fob, does the boot open up fully under its own control, or do you have to assist at some point for the boot to open, i.e. it opens only a couple of inches, and then you have to open the boot before the struts operate?
Thanks :wink:
RE: Question about Auto-boot function
Posted: Fri Sep 17, 2010 12:55 pm
by scottie1979
Mine opens all the way
Posted: Fri Sep 17, 2010 1:05 pm
by sonny
OK Thank you. does your boot lid have sprung loaded rubber bung (helper) at the edge of the boot lid?
Posted: Fri Sep 17, 2010 1:49 pm
by ^Qwerty^
Mine opens all the way too
Posted: Fri Sep 17, 2010 2:29 pm
by DuncS3
mine does if it feels like it - depends whether the car has a strop on - but yes it is meant to
Posted: Fri Sep 17, 2010 2:39 pm
by pad125
Did I see somewhere that the 'fully opening' boot lid was an option, something about the gas struts being a differant type IIRC
Posted: Fri Sep 17, 2010 2:45 pm
by Pie
Supposed to open all the way although a few weeks ago I seen a Merc which had auto boot closure too.
<3 Gadgets!
Re: RE: Question about Auto-boot function
Posted: Fri Sep 17, 2010 2:47 pm
by pippyrips
pad125 wrote:Did I see somewhere that the 'fully opening' boot lid was an option, something about the gas struts being a differant type IIRC
Correct, not a simple swap either as brackets etc also need to be changed.
RE: Re: RE: Question about Auto-boot function
Posted: Fri Sep 17, 2010 3:20 pm
by sonny
It was a £30 option.
You can have it fitted after market, all you need is the uprated piston, bracket and spring for each side, works out around £60 quid. Im having it fitted at the moment. just it a slight snag, where it wont open fully. so we are not sure if it needs a spring loaded grommet (like what is shown in the other thread about the rubber strip on boot). As these might have been added at a later date to stop the boot rubbing on the bumper...watch this space.
Can any of you guys confirm that you have the spring loaded grommet on the tail gate. thanks
Re: RE: Re: RE: Question about Auto-boot function
Posted: Fri Sep 17, 2010 3:26 pm
by PetrolDave
sonny wrote:It was a £30 option.
IIRC only on the saloon, not on the cab or Avant.
RE: Re: RE: Re: RE: Question about Auto-boot function
Posted: Fri Sep 17, 2010 3:30 pm
by sonny
Yep thats right Dave. But how "cool" would a avant auto boot be (even though it would have to be one strong strut).
Re: RE: Re: RE: Re: RE: Question about Auto-boot function
Posted: Fri Sep 17, 2010 4:22 pm
by PetrolDave
sonny wrote:But how "cool" would a avant auto boot be (even though it would have to be one strong strut).
I'd retrofit it if it were possible 8)
Posted: Fri Sep 17, 2010 5:57 pm
by gdavison
Pie wrote:Supposed to open all the way although a few weeks ago I seen a Merc which had auto boot closure too.
<3 Gadgets!
FWFW - RS6 C6 Avants have power boot close .. maybes look to see if anything retrofits to the RS4 Avant ?
Posted: Fri Sep 17, 2010 8:28 pm
by ArthurPE
mine only pops open a few inches, just unlatches
pretty sure all cars in the States are the same
no full opening option
Posted: Fri Sep 17, 2010 11:14 pm
by karl
I understood from my local dealer that new boot hinges are required as they're a different design. I've got all the part no's listed if anyone wants them.
