Backing it in!!
lengster1
Backing it in!!
Post by lengster1 » Tue Sep 07, 2010 12:17 pm
This is the best way i can describe a "moment" in the rs4,braking fairly hard into a right hander carrying the brakes into the turn,the arse end is light and results in a slide which required steering into,completely in its stride no fuss no drama but wouldnt mind dialing it out if poss what do you guys think? Anti roll bars will help im sure but weight transfer and brakes bias also? My drc is leaking at both fronts and knocking over speed bumps do you think this will contribute?
Revolution
Trader (Expired)
Post by Revolution » Tue Sep 07, 2010 12:40 pm
Hi Lengster
For my 2p worth and not wanting to lecture you at all but....
Thats a habit you need to get out of as it will catch you out one day.
Do your braking in a staright line, drop a gear and use the mechanical grip to power you round the corner.
If front end washes out - you have an option to back off gently to help you out.
If the rear kicks out - oppo lock and a bit of throttle should suffice.
Better still, turn off all the esp, traction malarky and you will enjoy yourself even more!!
I think bars and other upgrades will keep the car flatter but you will enter at a higher speed and the problem may be exaggerated.
Question if anyone knows:
I prefer to left foot brake and does anyone know if a remap can turn off the system that prevents throttle and brakes at the same time?
Hope that helps you and again not wanting to lecture anyone.
Glenn
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
Nib
Post by Nib » Tue Sep 07, 2010 12:54 pm
Revolution wrote: Question if anyone knows:
These insidious systems are creeping in all over the place on all types of cars. I even saw one article that claimed that cutting the throttle when using the brakes was a safety feature designed to prevent "Toyota-type" run away problems!
My mother's automatic Honda Jazz, which usually creeps, rolls backwards on any hill when you lift off the footbrake away from the lights. How dangerous is that!
I think you'll be struggling to deactivate it. No place for it on ANY performance car.
"It will never have enough power until I can spin the wheels at the end of the straightaway in high gear."
Mark Donohue on the 1,580bhp Porsche 917-30
PetrolDave
Re: Backing it in!!
Post by PetrolDave » Tue Sep 07, 2010 1:30 pm
lengster1 wrote:My drc is leaking at both fronts and knocking over speed bumps do you think this will contribute?
You're driving a car with faulty suspension that hard?
Sorry, but that's just crazy.
North_Wind
RE: Re: Backing it in!!
Post by North_Wind » Tue Sep 07, 2010 2:15 pm
Indeed. Brake on the straight. Drop a gear if you need. Constant throttle through the bend until you can see the horizon clear, then accelerate. Don't rely on all the gizmos to keep you right, not least because the habits will get engrained and you will get caught out in less well-behaved car.
adsgreen
Post by adsgreen » Tue Sep 07, 2010 3:05 pm
Now whilst there's nothing wrong with braking and turning... if you do right... in the instance above I think it's fair to say you were still braking too hard when you initated the turn.
Whilst you could adjust the suspension to deal with this case what you'll end up doing is have an understeering car in other not quite so extreme circumstances.
There's nothing you can do about weight transfer apart from taking some weight out of the car - this is a function of mass, centre of gravity and wheelbase. All adjustments to the suspension do is adjust how the car reacts to a given weight transfer load it doesn't stop the amount thats going on.
That being said, brake bias can help in these situations - if the back is stepping out that much under braking then move the bias forwards. That way you're giving the rears less work to do (more cornering than braking)
sonny
Post by sonny » Tue Sep 07, 2010 3:45 pm
One good thing about our AWD systems, is that you can trail brake longer, also apply accelerator prior to apex. The car has a tendency to naturally under steer do to the dynamics of the vehicle, i.e. engine forward of front Axel, Stiffer ARBs may exaggerate this as above.
lengster1
Post by lengster1 » Tue Sep 07, 2010 5:54 pm
Ok maybe ive not put it across vey well,i didnt go steaming in late on the brakes because id overcooked it,id trailed them in towards the apex because thats the best way of dealing with this particular selection of bends,ive done the road on many an occasion im many high performance cars/motorbikes but never had a car do this hence the post,does anyone else find they get light at the rear even in a straight line? My DRC is border line ok according to its seepage levels down the struts but am wondering how much pressure it may have lost,anyone else have the same handling findings under braking?
Revolution
Trader (Expired)
Post by Revolution » Tue Sep 07, 2010 6:24 pm
Thats a fair point - maybe get those checked out asap just to be on the safe side...
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
neckarsulm
Post by neckarsulm » Tue Sep 07, 2010 10:41 pm
Correct me if I am wrong but soft front shocks can cause roll over steer.
I had a moment on damp road when the rear felt like it went light, wasn't driving that full on either but maybe came off the brakes a little later that I should have - prob a B5 RS4 habit for me and Lengster, no chance of wagging one of those tails (unless your name is Lucas and you have 500+ PS)
caldy
Post by caldy » Tue Sep 07, 2010 11:41 pm
Didn't CAR Magazine describe the B7 RS4 as 'busy under braking'?
RS4 B7 Phantom Black
Dom81
Post by Dom81 » Wed Sep 08, 2010 12:09 am
caldy wrote:Didn't CAR Magazine describe the B7 RS4 as 'busy under braking'?
Evo certainly did - it's still there in the Knowledge, but of course gets a 5 star rating!
2007 Daytona RS4 Avant
Bladerider
Post by Bladerider » Wed Sep 08, 2010 2:53 am
You're describing one of my favourite driving sensations !!
Nothing wrong with it if you are inciting it on purpose, in fact it was the best way to get the GT3 to bite on the front end before planting the throttle on some bends !!
Not really pushed the RS4 yet so couldnt give an answer with any experience, but I would say that if your DRC is leaking and the shocks are possibly allowing more movement then perhaps the system is allowing more weight transfer forwards than the cars normal balance can handle and hence the rear end coming round a tad. Either way its hardly a deadly sin !!!
Enjoy yourself, thats why we buy these things.
j.
adsgreen
Post by adsgreen » Wed Sep 08, 2010 10:14 am
Shocks only affect how quickly the load from weight transfer reaches the tyre. Having a soft shock means it takes longer for the tyre to react to the weight conversely a stiff shock means the tyres gets loaded quicker.
Assuming the front shocks are shot and so considerably softer relative to the rear then the car will tend to oversteer.
lengster1
Post by lengster1 » Wed Sep 08, 2010 11:59 am
Arent the shocks linked across corners? So if the fronts have weeped and lost gas then the pressure will be reduced in the whole system yes? or are the fronts sealed independantly? surely not? This is what i have in the back of my mind,pressure is low and reducing damping pressure therefore allowing too much squating or weight transfer when pushed! Or is it a characteristic of the car?
Users browsing this forum: No registered users and 356 guests
