Page 1 of 2
Spacers?
Posted: Sun Jun 06, 2010 12:30 pm
by RS6chris!
I,m currently running 10mm rears and 8mm fronts....anyone running 15mm rears and 10mm fronts on here?
Would 15mm rears be too much? and do 10mm fronts work?
I have standard suspension?
Chrissy.
RE: Spacers?
Posted: Sun Jun 06, 2010 12:44 pm
by sonny
Porky is running 12mm on the rear. If your car is not lowered I would say it would be ok. You might get a bit of rubbing on full lock.
Bet it would look phat with 15mm's
RE: Spacers?
Posted: Sun Jun 06, 2010 4:51 pm
by approved
im running 10mm rear and nothing up front...
try that, might give you the stance your after...
Re: RE: Spacers?
Posted: Sun Jun 06, 2010 5:16 pm
by sonny
jonathonturner wrote:im running 10mm rear and nothing up front...
Pics? would like to see the stance, take it from about 3 meters back so it shows the wheels protruding out side the rear end 8)
Re: RE: Spacers?
Posted: Sun Jun 06, 2010 5:19 pm
by sonny
RE: Re: RE: Spacers?
Posted: Sun Jun 06, 2010 6:09 pm
by approved
wheels dont prutrude..they just sit flush..they are 10mm each side...?
Posted: Sun Jun 06, 2010 7:38 pm
by sonny
OK i still have my spacers to put on yet, still not got around to it. 10r/8f
Posted: Sun Jun 06, 2010 8:48 pm
by approved
i persoanlly thing the front wheels sit fine in the arch, and given they steer as well,i thoguht best to leave that end alone,,
so i went down the rear only, and am well happy.
i havent got any snaps of my avant, but here's my previous saloon, very dirty with just rears.
Posted: Sun Jun 06, 2010 9:15 pm
by lengster1
I run 10mm hubcentric rears and plain 3mm fronts
Posted: Sun Jun 06, 2010 10:15 pm
by P_G
I run 10mm rears only with 275 tyres which seems to do the trick. Wider spacers possibly if only 255 tyres but theoretcially only 3mm front 12mm rear?
Re: RE: Re: RE: Spacers?
Posted: Mon Jun 07, 2010 8:58 am
by sonny
jonathonturner wrote:i persoanlly thing the front wheels sit fine in the arch, and given they steer as well,i thoguht best to leave that end alone,,
It sits just right. I will have to get mine fitted, hopefully wont have any problems with my 20mm drop :roll:
RE: Re: RE: Re: RE: Spacers?
Posted: Mon Jun 07, 2010 9:24 am
by RS4KILLA
any more pics with spacers??
Posted: Mon Jun 07, 2010 10:27 am
by approved
10mm rears should be fine...whack em on..takes five mins..you'll wonder why you didnt do it before..
Posted: Wed Jun 09, 2010 6:00 pm
by Stevieb03
Hi - I have a question, When you talk about 10mm on the back and 8mm on the front is that per wheel or overall?
I'm currently looking at Eibach Pro spacers, could anybody tell me if they are any good and that they are hubcentric?
Thanks all
Posted: Wed Jun 09, 2010 6:07 pm
by sonny
That is per wheel, so 20mm axle width and 16mm axle length.
I have seen the Eibach spacers split before on a BMW, not good. H&R get the thumbs up from here. If it has a lip on the hub area then it is hub-centric, this is what you want.
