Page 1 of 3
SW0090 added today
Posted: Sat May 01, 2010 8:35 pm
by sonny
Took the car in for a service (4th service at 30k), Oil and filter change, Pollen filter change.
Had new front OEM Discs fitted today (Thanks Philwalker) and had EBC yellow stuff fitted front and rear, difference was amazing, even though they have not yet bedded in! My old pads was totally shot, and the 4 pins was seen coming through.
Also had
SW0090 uploaded to my car, I was still on
SW0040. The SW overwrite my MRC Remap as it would, and the difference was phenomenal, one thing I did notice was how quiet the car was on start up, on tick over the exhaust is now quiet, the car now feels like it is "tamed".
Im having the MRC Remap uploaded next week with some other goodies added
RE: SW0090 added today
Posted: Sat May 01, 2010 10:22 pm
by Outtlaw
Sonny, did you have all this done at Audi? (discs and pads) if so did they just charge you for the fitting?
Peter
Posted: Sat May 01, 2010 11:00 pm
by NIKKIrsSIXX
Please pardon my ignorance but what is SW0090?
Posted: Sat May 01, 2010 11:15 pm
by pippyrips
Im surprised you didn't have newer SW given MRC have mapped it, they usually upload a base map which is either 0080 or 0090 and tweak accordingly?
Posted: Sun May 02, 2010 11:15 am
by sonny
Outlaw yes Audi fitted them for me I supplied the pads and discs.
Nikk the SW0090 if a up dated software for the engine ECU, there as been numerous updates (this one solves a cold start up issue).
PR. It was identified at MRC that I had the old SW but was advised to get the latest added and then re-uploaded.
Posted: Sun May 02, 2010 12:12 pm
by RS4KILLA
how can you check which SW0090 SW0040 are you on?
Posted: Sun May 02, 2010 12:56 pm
by klauster
possibly vag.com, other than that you need someone to read the ecu... Audi or a tuner i'd imagine
Posted: Sun May 02, 2010 2:16 pm
by sonny
Yep as above, dealer hooked it upto there computer, gives fault codes and what SW you are running. Updating to SW0090 also has the other SW updates too.
Posted: Sun May 02, 2010 5:50 pm
by PetrolDave
VAG-COM shows the SW version when you connect to the engine ECUs (addresses 01 and 11).
SW0090 fixes a rich cold start problem and is only available on request - it's not offered automatically when you take your car to a dealer.
Posted: Sun May 02, 2010 8:13 pm
by NIKKIrsSIXX
Sonny - Thank you.
Posted: Mon May 03, 2010 11:14 am
by Jazza1984
0090 - without this, does the car 'roar' into life on the first start? I think i actually quite like that...Im even fond of starting the car when the door's open!
On an aside, as someone said this is only done on request - how many of the other recalls need to be requested? I thought Audi would've just done them when you came in for a service.
Posted: Mon May 03, 2010 11:27 am
by SR71
My understanding was that SW0090 was incepted to cure a particular problem with cold-starting that affected a certain range of chassis numbers.
When I asked for it, I was refused for the aforementioned reason.
However, when I discovered that SW0080 causes an oscillatory airflow rate as measured by the MAF (for some unknown reason) and that Doug had never seen a SW0090 car manifest this phenomenon, I went to Camberley and they did the SW0090 update for me.
Cured the my particular problem even though I had no cold-starting issues.
FWIW.
Posted: Tue May 04, 2010 9:15 am
by sonny
I will add, that there was other SW updated, (im not sure what and how many other updates there was) im guessing SW0050.SW0060.SW0070,SW0080,SW0090??? yes, no, if so, then the later would incorporate all of these, any body confirm?
Posted: Tue May 04, 2010 2:26 pm
by sonny
As my car was produced in 2006, it came with SW0040, updated at 80 and 90. later cars came with SW0050. the unrestricted variant sold to German customers was SW0030. answered my own questions there.
Posted: Sun May 23, 2010 5:58 pm
by Snodgrass
Had SW updated from 0080 to 0090 last week and the different cold start strategy is immediately noticeable even in this hot spell.
Initial rpm is higher, exhaust noise (in Sport mode) is louder and running is much smoother.
