Page 1 of 2
wheel spacers
Posted: Fri Mar 12, 2010 2:53 pm
by cushty
Hi all, im new to the forum, Was wondering if you guys can help me out...
Basically im looking for some (10mm rear/8mm front) wheel spacers + extra long nuts.
Where do i purchase some from?
RE: wheel spacers
Posted: Fri Mar 12, 2010 3:53 pm
by RS6chris!
The TT Shop...sorted me out H and R ones.
Posted: Fri Mar 12, 2010 10:50 pm
by zachf88
You can purchase some MTM's from me!!
http://forums.quattroworld.com/classifi ... 6093.phtml
Also, with the quattro system, it's best to run same thickness all-around
Posted: Sat Mar 13, 2010 5:32 pm
by cushty
Posted: Sat Mar 13, 2010 6:05 pm
by sonny
I have a set waiting to go on at the mo, got mine from Virdees Auto's on here.
Posted: Sun Mar 14, 2010 11:23 am
by WUZ
Sonny - how much do Virdees charge and do they come with extended bolts?
Russell
Posted: Sun Mar 14, 2010 1:58 pm
by sonny
WUZ wrote:Sonny - how much do Virdees charge and do they come with extended bolts?
Russell
Yes all in if you order them, PM him for price. cant remember what I paid.
Posted: Sun Mar 14, 2010 2:51 pm
by WUZ
Cheers Sonny, PM winging its way to Virdees as we speak.
Posted: Sun Mar 14, 2010 3:59 pm
by psg001
sonny, what size spacers have you got, 8mm front and 10mm rear??
am thinking this is definitely my next move, need to get those arches filled a bit more! might contact UNIT 20...
anyone gone for 10mm all round??
Posted: Sun Mar 14, 2010 4:38 pm
by lengster1
I couldnt find/buy 8mm hubcentric spacers for the front so fitted 3mm plain ones,any larger than this and your wheel WILL NOT be in contact with you hub,it will just be the bolts alligning the wheel,the inner bore of the alloy is only the correct diameter to mate with the hub approx 5mm into the wheel so if you pack it out by more than that and dont use hubcentric your putting all shear loads through your bolts and not the hub,i wouldnt be a passenger in such a car driven at speed thanks
Posted: Sun Mar 14, 2010 5:52 pm
by sonny
I have 8mm Front and 10mm Rear (not yet fitted) H&R Hubcentric spacers. size you will need is the 150mm face. the bolts are the 35mm (I think) ones, Virdee no doubt will confirm, I am not at home at the moment so can not confirm.
Few guys are running 8 fronts and 10 rears on here. I think Porky was running 10s all round on his cab.
Posted: Sun Mar 14, 2010 7:32 pm
by psg001
so does that mean if you can get 8mm hubcentric spacers then its ok because its not just the bolts taking all the force / attaching the wheel to the hub???
Posted: Sun Mar 14, 2010 7:51 pm
by sonny
psg001 wrote:so does that mean if you can get 8mm hubcentric spacers then its ok because its not just the bolts taking all the force / attaching the wheel to the hub???
Yes Hubcentric means it has a lip and the weight is resting on that and not the bolts, and yes this applies to the 8mm, infant all hubcentric spacers, even the 50mm ones
There have been horror stories of spacers coming off, and even cheaply made hubcentric ones splitting at the base, Over on a BMW forum it happened to a guy on there who was running a 330ci. they was not made by H&R.
Posted: Sun Mar 14, 2010 10:04 pm
by psg001
ok, good, I had some H&R hubcentric 10mm rear spacers on my A3 a few yrs ago.
Posted: Mon Mar 15, 2010 12:30 am
by WUZ
Goody goody, just waiting for the confirmation from Virdee that they are Hubcentric 8mm spacers and the order will go in
Cheers Sonny!
Russell
