Can you swap standard brakes for ceramics ?
Posted: Mon Feb 15, 2010 5:14 pm
by victor2vt
Just wanted to know what would be involved if a write off had undamaged ceramic set up on, what would be involved in fitting them ?
Posted: Mon Feb 15, 2010 5:22 pm
by P_G
so long the mounting brackets, calipers, discs and pads are part of the deal it should be feasible.
Posted: Mon Feb 22, 2010 5:08 pm
by citanest
just curious, is it necessary to upgrade the rear brakes to balance the braking power?
Posted: Mon Feb 22, 2010 5:24 pm
by marcr
I wouldn't have thought so as many people upgrade fronts, discs, calipers, pads, hoses etc and leave rears alone.
Posted: Mon Feb 22, 2010 7:57 pm
by Virdee Autos
Cars specified with ceramic, have the same steel rear brakes as normal RS4 with steel fronts
Re: Can you swap standard brakes for ceramics ?
Posted: Mon Feb 22, 2010 10:16 pm
by ollys
victor2vt wrote:Just wanted to know what would be involved if a write off had undamaged ceramic set up on, what would be involved in fitting them ?
You have to tell the ABS to work with Ceramics AFAIK, but I think this can be done by someone who knows about that sort of thing...
Posted: Mon Feb 22, 2010 11:50 pm
by citanest
marcr wrote:I wouldn't have thought so as many people upgrade fronts, discs, calipers, pads, hoses etc and leave rears alone.
Thanks. I should have asked if there is advantage in upgrading the rear?
there doesn't seem to be any options available for the rear?
Posted: Tue Feb 23, 2010 10:44 am
by pad125
citanest wrote:just curious, is it necessary to upgrade the rear brakes to balance the braking power?
The rear steel discs are the same.........they warp just the same as the all round steel brakes unfortunately
