Page 1 of 2
Few more questions
Posted: Thu Jan 14, 2010 5:23 pm
by johninspain
Firstly can you tell im bord ? Secondly sorry for all the different posts, i just like to know what im dealing with !
what oil are you all on ?
can it run on 95 fule ?
Has anyone used an additive, for boostingthe octain or for cleaning the motor ?
RE: Few more questions
Posted: Thu Jan 14, 2010 5:27 pm
by HYFR
dont run it on 95 fuel, i run on 99 only
Posted: Thu Jan 14, 2010 5:30 pm
by gmk666
I'm using Castrol Edge, 5w30. It's VW 504 507 rated and I'm told is what the car came with from the factory.
I've only ever used 95RON fuel in an emergency - not all small garages in the UK have the much more preferred 98RON.
by johninspain
98 is the best out here,,,,,, if your lucky.....
Posted: Thu Jan 14, 2010 5:33 pm
by Outtlaw
Only run it on 99 but if stuck put a little of 95 till you see the next petrol station, as for oil i use castrol but you have to check the dipstick constantly.
Posted: Thu Jan 14, 2010 5:34 pm
by Outtlaw
urrrrr i type to slow.
Posted: Thu Jan 14, 2010 5:49 pm
by sonny
Castrol Edge 5w30
97/98 and 99 RON fuel.
Does Spain have the same RON rating as the UK, I know in the states its different, 93 RON is 98 RON UK. (Arthur correct me). what does it say on the inside of your filler cap, should have it in a Spanish RON.
Re: RE: Few more questions
Posted: Thu Jan 14, 2010 5:51 pm
by johninspain
sonny wrote:Castrol Edge 5w30
good idea !
RE: Re: RE: Few more questions
Posted: Thu Jan 14, 2010 8:11 pm
by PetrolDave
AFAIK the EU all use RON octane ratings, where the US use the average of MON and RON ratings.
Posted: Thu Jan 14, 2010 9:17 pm
by MB2
I haven't had mine too long & have run it mostly on Shell Super 99 or whatever it is called. If I know will be doing a long mway run I tend to top up with std UL as is a bit cheaper although many say the mpg is better with the higher octane stuff. I used to run my R32 (also meant to have super) on std & was fine but am more careful with the RS4 as engine is in a higher state of tune. Oil I use Castrol Edge (left over from the R32 but correct spec for both cars)
Posted: Thu Jan 14, 2010 9:22 pm
by johninspain
so 95 for a m way run ?
Posted: Thu Jan 14, 2010 9:28 pm
by sonny
It will cost you more to use the cheaper fuel lol due to the burn rate of the fuel. so even if the fuel is more expensive you will get more MPG from it, there for it is actually cheaper.
Posted: Thu Jan 14, 2010 10:23 pm
by P_G
johninspain wrote:so 95 for a m way run ?
I wouldn't bother TBH. I used to do that but the mpg difference is about 10% worse with 95RON unleaded in the UK and costs 3-5% less so no gain at all. Better to economise your use of your lead foot.
Plus the RS feels dog rough and takes a couple of tanks of 98/99 to get its normal sharpness back.
There is also a theory posted on this forum that using 95 RON may contribute more to carbonisation of the valves. It say on the filler flap min 97 RON, it is usually for a reason.
Posted: Thu Jan 14, 2010 10:38 pm
by johninspain
just looked at filler cap, says 98 or 95................
Posted: Thu Jan 14, 2010 10:40 pm
by P_G
Using 95 won't get all the ponies or torques working in your engine either.
