struggling with bluetooth
Post by HYFR » Thu Dec 10, 2009 10:30 pm
hi guys
My RS 4 has GSM phone prep which i believe therefore includes Bluetooth...
How do I connect my phone?
I have a Nokia E63 and when I try to pair, what device will the RNSE come up as ?
aidanjaye
Post by aidanjaye » Thu Dec 10, 2009 10:46 pm
I think it shows up as AUD or such like.
I had problesm to begin with. Follow this procedure.
1. Turn on blue tooth on your phone.
2. Go out to car and switch ignition on (dont start)
3. Search for bluetooth devices on RSNE
4. You will then be prompted for a code (think its 1234).
You only have a certain amount of time to connect.
Once connected, the tel prep remebers your phone and connects each time you get in the car.
aidanjaye
Post by aidanjaye » Thu Dec 10, 2009 10:47 pm
and why has your sig picture turned upside down??
P_G
Post by P_G » Thu Dec 10, 2009 10:48 pm
It usually comes up with Audi-UHV 4762. Pin is 0000 or 1234, can't remember which. Easiest to switch ignition to prep and then try and discover the bluetooth module through your phone than the other way round.
2 minute job but like said previously you only have a period of IIRC 2 minutes after ignition switch before the module disables itself in which to initially pair.
Post by HYFR » Thu Dec 10, 2009 11:33 pm
superb
many thanks guys
just went out and tried it and it works!
so, couple of more questions if you could be so kind
- is there a quick way to sync my phone book?
- how do I set the "voice" names in the address book....i.e. when I get the voice command going and say "select name" she says which name please....how do I add "voice" names ?
Cheers!
ps. why had my avatar gone upside down ?!
aidanjaye
Post by aidanjaye » Fri Dec 11, 2009 1:40 am
Tried a quick way to sync my phonebook but never managed. Didn't know the system allowed voice control???? Maybe I should read my handbook.
P_G
Post by P_G » Fri Dec 11, 2009 10:21 am
You can only get voice control if you have SDS, don't know many cars with his function and IIRC it is a separate button on the dash (or that is how it is retrofitted anyway with non MFSW, i.e. flat bottom RS wheel)
Marcus-RS4
Post by Marcus-RS4 » Fri Dec 11, 2009 10:25 am
If you have a phone cradle, you have SDS - you just need your adaptor of choice to use it (else you don't have a button to press to activate it!)
PetrolDave
Post by PetrolDave » Fri Dec 11, 2009 10:29 am
Guys - there are 2 versions of SDS.
Partial SDS that comes whenever you have the Audi phone kit. This allows you to voice dial, that's it.
Full SDS that only comes when you have a special version of the RNS-E ans which allows you to controlmany functions of the RNS-E as well.
Post by HYFR » Fri Dec 11, 2009 1:25 pm
I have partial SDS then, as when I press the button on the cradle, she asks me to speak a command
So....any ideas how to store voice commands (i.e. names)
Marcus-RS4
Post by Marcus-RS4 » Fri Dec 11, 2009 1:29 pm
If you wait without saying anything, she will say "Pardon"... then after another little wait "Pardon"... then she will go through the possible commands :)
Post by HYFR » Fri Dec 11, 2009 2:18 pm
cheers Marcus, but not the answer !
guess im gonna have to read the book
the previous owner has names stored in there, but I want to store my own so I can
- press the button
- say the name
and it calls
PetrolDave
Post by PetrolDave » Fri Dec 11, 2009 2:44 pm
Press the PTT button and say "store name", you'll then be guided through entering the name and phone number.
Stigter
Post by Stigter » Sat Dec 12, 2009 6:20 am
or push ptt button and say Help - it will give you... well help I guess.
mark758
Post by mark758 » Sat Dec 12, 2009 12:27 pm
PetrolDave wrote:Full SDS that only comes when you have a special version of the RNS-E ans which allows you to controlmany functions of the RNS-E as well.
In case folks are blissfully unaware they may have this feature ..... is there a simple way to tell if you have full SDS including Nav commands Dave? cheers mark
Users browsing this forum: No registered users and 169 guests
