Sad or Mad???
Posted: Tue Jun 30, 2009 6:22 pm
by chrissyr32
Well guys got in from work early so i thought i,d give the old girl a clean. Wheels and calipers etc looking a bit worse for wear.. so as follows>
Wheels off fully cleaned including AG tar remover..boy that stuff is good and polished.
Calipers discs rotors etc, washed degreased and POLISHED!!
Holes in discs cleaned out using 4mm drill bit (boy they were blocked up)
Arches and suspension arms etc washed and degreased.
Studs copper greased etc and all put back together.
She looks BRAND new.
Anyone else actually enjoy doing this?? Am i mad or sad???
Chrissy.
RE: Sad or Mad???
Posted: Tue Jun 30, 2009 6:45 pm
by approved
mad...
hats off to you though
Lol
Re: RE: Sad or Mad???
Posted: Tue Jun 30, 2009 6:59 pm
by toomuch
jonathonturner wrote:mad...
Lol
but jon your the laziest bastid on the planet
Posted: Tue Jun 30, 2009 7:08 pm
by approved
toomuch wrote:jonathonturner wrote:mad...
Lol
not true..thats your mrs.
Posted: Tue Jun 30, 2009 7:17 pm
by toomuch
jonathonturner wrote:toomuch wrote:jonathonturner wrote:mad...
Lol
now now your only saying that cause shes in malia
RE: Re: RE: Sad or Mad???
Posted: Tue Jun 30, 2009 7:27 pm
by sonny
Posted: Tue Jun 30, 2009 7:34 pm
by P_G
Wheels, top man; calipers maybe, but suspension and rotors!
You are half a dozen walnuts too much for a Tracker bar!
Posted: Tue Jun 30, 2009 7:54 pm
by chrissyr32
Top tip...or nerdish fact of the day.. the rear discs only have holes in the outer disc.. as i found out when i tryed to drill them out!!!
and the holes are 4mm exactly...
Amazed at how much crap came out of them mind. The discs have instantly rusted so all my work may be slightly spolit next time i take her out..
On a different note.. shocks look perfect. no leaks strange how some cars are affected and some arent with DRC isues.. a bad batch of shockers maybe??
Posted: Tue Jun 30, 2009 8:41 pm
by rAudiguy
Chris, top tip of the day for you then! After the car is dry, take her for a short drive. Apply the brakes with your left foot and clean the discs off. Then drive a bit more and let the air dry the disc. Come back wipe the wheels clean again as some crap will have come off the discs and bingo u have shiney dry rust free discs!!
Re: Sad or Mad???
Posted: Tue Jun 30, 2009 10:10 pm
by ArthurPE
chrissyr32 wrote:Well guys got in from work early so i thought i,d give the old girl a clean. Wheels and calipers etc looking a bit worse for wear.. so as follows>
Chrissy.
rest assured, you're not the only fanatic around here
Posted: Wed Jul 01, 2009 10:24 am
by aidanjaye
How long did you stare at the discs when you removed the wheels - I spent a good 20 mins....mad or sad??
Posted: Wed Jul 01, 2009 6:25 pm
by sumdy
Had the front wheels of yesterday to give em a good clean,also drilled out the holes in the discs,loads of crap in em.
Posted: Wed Jul 01, 2009 8:35 pm
by chrissyr32
sumdy wrote:Had the front wheels of yesterday to give em a good clean,also drilled out the holes in the discs,loads of crap in em.
I,m not the only one!!! Wahey...
Posted: Thu Jul 02, 2009 11:05 am
by klauster
chrissyr32 wrote:sumdy wrote:Had the front wheels of yesterday to give em a good clean,also drilled out the holes in the discs,loads of crap in em.
but you are still mad
