Page 1 of 2
First Modifications....
Posted: Wed Jun 24, 2009 12:23 pm
by approved
have sorted the musical side of things out, and am more than happy with the noise/pace, but cant help but think that the wheels are too far into thearches for me...
anyone on here running spacers?
i was thinking 10mm front and 15mm rear?
am keen to avoid rubbing as my suspension is the plus version..so already quite low..
what say thee?
RE: First Modifications....
Posted: Wed Jun 24, 2009 1:18 pm
by rjkflyer
At the risk of incurring great wrath...
Spacers = visual appeal only.
Spacers = upset the front suspension geometry adversely.
Re: RE: First Modifications....
Posted: Wed Jun 24, 2009 2:54 pm
by primus2211
rjkflyer wrote:At the risk of incurring great wrath...
Quite interested to get some feedback to this as well since I'm thinking of changing the wheel. Facing problem finding ET 29, most has been ET 22 or 20. Same concept as spacers, any feedback from others who has done either spacer or wheel change? Thanks! :D
Posted: Wed Jun 24, 2009 3:06 pm
by UNI555
If you use a spacer to correct the wheel offset and the wheel ends up with the same orientation around the hub as intended then it should be fine (I did this to fit my RS6 rims). This isn't quite the same as moving the wheel bodily outwards with spacers, I have no experience of doing that and those that have seem to have had no problems, but in theory it might have adverse affects on the geometry as rkflyer says, and also potentially on wheel bearing life.
RE: Re: RE: First Modifications....
Posted: Wed Jun 24, 2009 3:16 pm
by UNI555
But I've just noticed that you are looking at wheels with too small an offset, rather than to large, so I got the wrong end of the stick there!
Posted: Wed Jun 24, 2009 4:09 pm
by approved
does anyone on here run spacers at all?
the mtm cars all run them as widened track assists stabilty when pushing on in high power cars...by all accounts would also help what little understeer was there as well.
anyone with any technical know how like to elaborate on this?
Posted: Wed Jun 24, 2009 4:36 pm
by pippyrips
I picked some spacers up recently but as yet have not fitted them.
I know others have used them and had no problems, ive also asked MRC about whether they would have a negative affect and they suggested they could actually improve handling.
Posted: Wed Jun 24, 2009 5:50 pm
by approved
qst and aps concur with the above.
wouldnt mind seeing some on a car to make sure my idea's on stance are about right.
Posted: Wed Jun 24, 2009 6:40 pm
by b7rs4saloon
8mm front 10mm rear.
No problems at all.
On my TTS I run 20mm rear and 15mm front, also no probs....
Posted: Wed Jun 24, 2009 6:52 pm
by rAudiguy
I'm running 8mm on the front and 10mm on the rear although I think the 8's are a tad big and may change them to 6's
Posted: Wed Jun 24, 2009 7:02 pm
by b7rs4saloon
Smallest hub centric are 8mm.
6mm will wobble!
Posted: Wed Jun 24, 2009 8:05 pm
by approved
need to see some pics if possible?
are either of you running sports suspension plus?
Posted: Wed Jun 24, 2009 10:14 pm
by almoRS
My wheels are ET32 with 3MM spacers to take them to ET29. No problems.
Re: RE: Re: RE: First Modifications....
Posted: Wed Jun 24, 2009 10:29 pm
by rAudiguy
b7rs4saloon wrote:Smallest hub centric are 8mm.
6mm will wobble!
Sorry you're Wrong! The smallest hubcentric is 3mm then 5mm, 8mm 10mm etc.
it was 5mm I meant not 6mm.
I will try and get some pictures up on Saturday.
Jim
Posted: Thu Jun 25, 2009 2:48 am
by ArthurPE
rAudiguy wrote:I'm running 8mm on the front and 10mm on the rear although I think the 8's are a tad big and may change them to 6's
this is good info...6 mm would seem to be a good choice...
or 9.5" with a 29 offset...+ 6mm...
