Page 1 of 2
What warranty work have you had done?
Posted: Fri May 15, 2009 1:06 pm
by stenning
I am trying to compile a list of potential warranty issues on the B7, would it be possible to post warranty work you have had done here and I will try and compile a full list at the end.
Thanks in advance for your help!
RE: What warranty work have you had done?
Posted: Fri May 15, 2009 1:26 pm
by PetrolDave
0080 SW upgrade - that's it.
Re: RE: What warranty work have you had done?
Posted: Fri May 15, 2009 1:42 pm
by Andyuk911
PetrolDave wrote:0080 SW upgrade - that's it.
You fib .. what about the Nav disc for TMC .... :lol:
RE: Re: RE: What warranty work have you had done?
Posted: Fri May 15, 2009 1:54 pm
by Dom81
SW upgrades (which might be warranty work, but certainly not an "issue"), a squeaky seat and DRC
No doubt most people have had something done - unique to them (or a small group) in many cases - and I'm not exactly sure how a list of these would help
Isn't it a bit like asking who's been to the doctors, and what for? You'd never leave the house...
Posted: Fri May 15, 2009 1:56 pm
by P_G
I thnk it is safe to say DRC and brake discs are the two most notable ones. I have also heard of clutch / pipe but touch wood have never had anything like this done on mine.
Nothing else for me.
Posted: Fri May 15, 2009 2:14 pm
by stenning
Thanks, what was the issue with brake discs?
In terms of "Isn't it a bit like asking who's been to the doctors, and what for? You'd never leave the house..." I think the use will be for owners to check before the cars goes out of warranty, the same as life insurance companies ask for a medical before providing cover, they check the basics not every possible medical problem.
Posted: Fri May 15, 2009 3:36 pm
by chrissyr32
Where do you want me to start???
Faulty low break pad sensor
Knackered valve in drivers seat to inflate bolsters
Creaking interior trim "A" pillars.
Corrosion on alumimnuim boot strip
Failed coil pack cylinder 8.
Fuel sensor recall
Battery holder recall.
Loose drivers door handle exterior.
ALL fixed under warranty though never cost me a penny apart from fuel to and from dealers.
BUT i still love this car!!!!!
Posted: Fri May 15, 2009 4:06 pm
by PetrolDave
That wasn't a warranty issue for me - I got hold of the disc from contacts in Europe three months before it was available in the UK.
Posted: Fri May 15, 2009 4:20 pm
by klauster
DRC obviously
front brake disks
engine mounts
couple of recalls - nothing major
Still hoping to get some work done through the warranty at the moment - ECU update for starters...
Posted: Fri May 15, 2009 7:31 pm
by Boots
DRC - 2 shock absorbers
Battery holder
New front seat clips
Loose trim in boot
New engine
Posted: Fri May 15, 2009 7:42 pm
by Oli
DRC - All
Battery tray
Wheel bearing
MAF - Ongoing........
Posted: Fri May 15, 2009 7:43 pm
by P_G
Blimey, a new engine is a new one! What did you do to the old one?
Posted: Fri May 15, 2009 7:49 pm
by Dom81
Love the way that it's last on the list, after a bit of trim!
Posted: Fri May 15, 2009 8:42 pm
by rjkflyer
RECALL
Fuel sensor recall
ADVISORY
Battery tray advisory (crack in floor)
Power steering fluid change advisory (noisy pump)
0090 sw advisory (major improvement to cold running)
TMC sw update (cos it should work!)
FAILURES
One adaptive xenon replaced on day two of ownership
At least 8 or 10 shock absorbers (now seems OK)
2 coil packs on same cylinder (suspect faulty plug as fault came up and recurred within a month, then gone with new plugs)
Posted: Fri May 15, 2009 8:43 pm
by Oli
Rik, the PAS fluid change - was that to cure the groan on lock?
