lights keep flickering
Posted: Fri Jan 23, 2009 2:28 am
by jacksrs4
my front lights keep flickering is there a cure or do i take it back to audi does this happen to anyone else. 8)
RE: lights keep flickering
Posted: Fri Jan 23, 2009 9:17 am
by booski
Never heard of that problem mate, might be a dealer visit is in order.... Probably a simple electrical fix though, hopefully. Good luck
Posted: Fri Jan 23, 2009 12:38 pm
by pippyrips
I had this problem assuming we are talking about the main beams?
It happened each time i drove over a manhole cover/uneven road etc.
The problem was cured by having two new headlight ecu's installed under warranty.
Posted: Fri Jan 23, 2009 4:06 pm
by bn8959
Is it both or just one? I had this with the xenons on my Mondeo (one would flicker a lot, then go out after a random amount of time). It was the Xenon bulb going, I left it too long and it eventually blew and took the ballast with it :(
Not sure if Audi will cover the bulbs under warranty, if not I got my replacement from www.hids4u.co.uk (that was for the Mondeo)- I think they are the same D2S type bulb in the RS4.
Re: RE: lights keep flickering
Posted: Fri Jan 23, 2009 4:49 pm
by pippyrips
pippyrips wrote:I had this problem assuming we are talking about the main beams?
Just to add this was only happening on the drivers side.
Posted: Sun Jan 25, 2009 1:28 am
by jacksrs4
it happens to both, even driving straights, thanks :? for the advice, will contact dealer on monday.
Posted: Sun Jan 25, 2009 4:26 am
by wankeldude
mine just got fixed for that exact flickering issue. new ballast under warranty. If your service rep doesn't believe it or pushes you more towards new bulbs, just tell them to replace the ballast and if it still flickers, you'll eat the old ballast (literally, stick it in your mouth and swallow it)
