First sign of a leak!
Posted: Wed Nov 26, 2008 8:57 pm
by al'srs4
Has anyone got any pics of a leaking shock. Had my front wheels off the other day and there looked to be some sort of dampness on the front drivers shock cover, admittedly there was alot of oily dirt about.
But, I suspect the dreaded DRC issue, although no handling probs up until I replaced all four tyres - reason for wheels being off.
Posted: Wed Nov 26, 2008 9:15 pm
by P_G
If they are just damp you won't get them changed, they supposedly do become damp under normal tolerances. And when I say damp I mean residue but not glossy. When they leak it looks like liquid.
I took mine in when this happened and that was the advice given. You will know when the DRC goes because an RS will not handle properly in the corners and you wil feel every surace through the wheels.
Perhaps this may be contributing to your F1 problems as well if it is severe.
Posted: Wed Nov 26, 2008 9:27 pm
by al'srs4
Maybe so Pig, I know the handling went off when the new tyres were fitted. Got to get it sorted as I am off on the rally next week and will be doing some serious diving around welsh roads.
Posted: Wed Nov 26, 2008 10:28 pm
by booski
al'srs4 wrote:Maybe so Pig,.
i think his handle is P G..... lol
Posted: Wed Nov 26, 2008 10:35 pm
by al'srs4
Oops, sorry mate, no offense meant!
Posted: Wed Nov 26, 2008 10:43 pm
by shunt1tech
Hi there , If your in any doubt have to pressures checked and if the misting has caused reduced pressures in the balance valve ,this will not help the handling issue you have .
Your local dealer should be able to check your damper pressures as a while you wait job and should take no longer then 30 mins.
If not come and see me at Camberley Audi.
Thanks Stu.
Posted: Thu Nov 27, 2008 2:10 pm
by Marcus-RS4
I took mine to Stu on his recommendation due to some knocking (I have my car serviced and maintained there anyway).
It turns out the shocks were damaged (second pair) and its in for repairs again.
Its a very subtle change you feel when the DRC has started to go, but it definitely exists - when its working properly, its a dream and any deviation from that just isnt right!
get it checked out, what's the worst that could happen, get it checked out and its all fine? - piece of mind at the least?
Posted: Thu Nov 27, 2008 3:06 pm
by drcarrera
P_G wrote:If they are just damp you won't get them changed, they supposedly do become damp under normal tolerances. And when I say damp I mean residue but not glossy. When they leak it looks like liquid.
Correct!
The pic I took here (half way up page) :
http://www.rs246.com/index.php?name=PNp ... ht=#275863
shown's mine before I took it to the dealer. They sybsequently said it was within normal parameters ...
