Page 1 of 4
new boots
Posted: Fri Nov 14, 2008 11:56 am
by al'srs4
Just about to by some new tyres: Goodyear Asymmetric in 275/30 x 19
Can anyone tell me if the above size is okay for all four corners or are the ones at the back different? I guess they should be the same, only these are slightly over sized to fill the arches so a bit unsure what I should be ordering.
Cheers alex
RE: new boots
Posted: Fri Nov 14, 2008 12:33 pm
by sonny
All 4 tyrs should be the same due to the 4wd (someone correct me if im wrong)!
RE: new boots
Posted: Fri Nov 14, 2008 12:34 pm
by RS44ME
Further, could anyone show us some pics of what the B7 RS4 looks like with 275/30R19s ?
Also, how much does this put the speedometer out by ?
Re: RE: new boots
Posted: Fri Nov 14, 2008 1:26 pm
by PetrolDave
RS44ME wrote:Further, could anyone show us some pics of what the B7 RS4 looks like with 275/30R19s ?
IIRC there's already some pics on here.
The speedo over-reads by a further 2%, since the RS4 already over-reads by about 5% that makes it about 7% (still within the C&U Regs limit of 10%).
FWIW my previous S4s have had much more accurate spedos which over-read by only 2%.
All values compared to a GPS speedo.
RE: Re: RE: new boots
Posted: Fri Nov 14, 2008 1:43 pm
by al'srs4
Be very interested to see any pics, does anyone have a link or jpeg handy!
:D
Posted: Fri Nov 14, 2008 2:09 pm
by RS44ME
Just spent 30 minutes searching and trawling this site and others - cannot find any B7 pics with 275s - all help, pics or links welcome
Posted: Fri Nov 14, 2008 2:10 pm
by RS44ME
PetrolDave - thanks for the speedo info !
Posted: Fri Nov 14, 2008 2:33 pm
by PetrolDave
Try here http://forums.audiworld.com/rs4b7/msgs/82085.phtml
They're not Goodyears but they are 275/30 19s
Posted: Fri Nov 14, 2008 3:19 pm
by Andyuk911
Re: RE: new boots
Posted: Fri Nov 14, 2008 4:36 pm
by Dom81
PetrolDave wrote:FWIW my previous S4s have had much more accurate spedos which over-read by only 2%.
My findings exactly...
Posted: Fri Nov 14, 2008 8:07 pm
by al'srs4
Some interesting threads/links. Does anyone know if the tyre pressure differs fitting these wider tyres to the smaller spec rim.
Posted: Fri Nov 14, 2008 8:10 pm
by P_G
I'm running mine at 39 front and 38 rear after some toying around with pressures, gives good grip without making the ride uncomfortable and feeling every bit of aggregate in the road when at higher pressures with associated noise.
Posted: Fri Nov 14, 2008 8:14 pm
by PetrolDave
P_G wrote:I'm running mine at 39 front and 38 rear
Same here - and I've recoded the TPMS to reflect the higher pressures I'm running.
Posted: Fri Nov 14, 2008 8:21 pm
by P_G
Recoded? Do you just not reset your TPMS vis DIS ASAP RSVP? :wink:
Posted: Fri Nov 14, 2008 8:35 pm
by PetrolDave
P_G wrote:Recoded? Do you just not reset your TPMS vis DIS ASAP RSVP? :wink:
Not if you want it to alarm at the same difference from your new "normal" pressures.
See here http://wiki.ross-tech.com/index.php/Aud ... Monitoring
