Page 1 of 3
Torque wrench for RS4
Posted: Tue Aug 26, 2008 2:12 am
by Ozrs4
Guys, does anyone know the torque amount to tighten our wheel nuts on the RS4? Does anyone bother or do you all just tighten it as hard as you can? Thanks.
RE: Torque wrench for RS4
Posted: Tue Aug 26, 2008 7:00 am
by ChrisRS4
IIRC its 120nm for wheel bolts.
Posted: Tue Aug 26, 2008 8:49 am
by rjkflyer
Yep, 120Nm for the RS4 8E, and 140Nm for the RS4 8D. From the Audi Workshop manual.
Posted: Tue Aug 26, 2008 8:53 am
by rjkflyer
And NO, NOT as TIGHT AS YOU CAN. If you use excessive torque the bolts can actually come UNDONE.
Why? Because if you stress steel too much it hardens. Correct operation of bolts assumes that there is some elasticity in the material so that when you tighten them correctly they exert some 'self-tightening' due to the elasticity. If they're grossly overtightened esp. repeatedly, then they are so hard they don't have an elasticity (they've gone beyond their 'elastic limit') and so no matter how tight you do them up they can work loose.
Posted: Tue Aug 26, 2008 9:04 am
by Ozrs4
Thanks all. I'll be getting a torque wrench and a proper hydraulic jack so I can take the wheels off for proper cleaning and to check on any future leaking shock (I don't have too much faith with this leaking shocks issue).
Posted: Tue Aug 26, 2008 12:23 pm
by dom888
I'm looking at buying a torque wrench of Fleabay. Do I need a 1/2" or 3/8" one? And apart from buying one that goes up to the required 140nM, is there anything else I need to ensure?
Posted: Tue Aug 26, 2008 1:01 pm
by PetrolDave
I would go for the 1/2" one - it's less likely to shear.
I sheared a 3/8" drive socket while trying to undo the wheel nuts on a previous car (that had been done up with an air wrench by a tyre fitter).
Posted: Tue Aug 26, 2008 2:52 pm
by pippyrips
Try MachineMart a stand alone torque wrench, then need a separate, thin walled socket. From memory its 13mm but sure others will confirm.
Posted: Tue Aug 26, 2008 5:37 pm
by PetrolDave
I thought it was 19mm?
Posted: Tue Aug 26, 2008 8:30 pm
by rjkflyer
Most Audi wheel bolts are 17mm.
Suggest you get a deep 6-point (as opposed to 12-point) socket, which means it's nice and long to get into the wheel bolt 'hole' without scuffing the wheel with the torque wrench itself and also 6-point stronger and 'looks' like a nut as opposed to a 12-point one which looks like a double star.
Re 3/8" vs. 1/2", 3/8" nicer to use but agree that unless you buy a top quality 3/8" drive (like SnapOn) then you're best with a 1/2" one for heavier use with wheel bolts.
Posted: Tue Aug 26, 2008 9:37 pm
by beauphoto
Draper also do a plastic covered socket that stops any wheel damage. Works really well.
Posted: Tue Aug 26, 2008 11:42 pm
by dom888
blimey, i never realised how much there was to know... to save me searching, does any know THE definitive model/make to get?
Posted: Wed Aug 27, 2008 5:45 pm
by Plodwyn
just ordered mine from draper tools come as a 3 socket set with internal and external nylon covering part number 59080 £41.59 inc p&p and vat. they also do a deeper socket set for £60 odd part number 40102
Re: RE: Torque wrench for RS4
Posted: Wed Aug 27, 2008 10:21 pm
by Ozrs4
For those is Aust, this is what I found for a reasonable price around $90AUD:
Kincrome Micrometer Torque Wrench 1/2". #MTW150F
• Manufactured from nickel chrome plated alloy, 1/2â€
Posted: Thu Aug 28, 2008 9:10 am
by RS4Molar
[quote="Ozrs4"]For those is Aust, this is what I found for a reasonable price around $90AUD:
