Page 1 of 2
My stereo turns it's self back on when I take the key out!!!
Posted: Mon Aug 18, 2008 9:09 pm
by rAudiguy
Hi Guys,
Been away on holiday for a couple of weeks and so just jumped back in the motor this morning. Got to work and pulled the key out, as normal the stereo/MMI turned it's self off and bleeped to show disconection of the blue tooth. Then only a couple of seconds later the music came back on! I put the key in again, turn the ignition on and then off again but it still was on so just pushed the button to turn it off.
On my way home turned it on again and everything worked fine, listen to a bit of music on the SD card slot but again when I got home it did the same thing!!
Anyone else had this before? Any Ideas?? PetrolDave need your help mate!!!
cheers
Jim
RE: My stereo turns it
Posted: Mon Aug 18, 2008 9:19 pm
by pippyrips
Although i've come across other types of odd behavior from time to time i've never had this!
I'm guessing you haven't used vag-com etc since this started so coding etc should be the same? - its the only thing i can think of :?
Try running a scan with vagcom and see if it throws anything up.
Posted: Mon Aug 18, 2008 9:25 pm
by rAudiguy
it did go in for DRC before I went away and in honesty i've only driven it 2 miles from the dealer until today but don't recall it doing it when I got back. Will pop down in the morning and get them to check it out I think.
Posted: Tue Aug 19, 2008 10:38 am
by Norrs2
There's a Ghost in your car that likes music??? :lol:
Seriously, could it be something to do with your Bluetooth installation??
Posted: Tue Aug 19, 2008 11:20 am
by PetrolDave
Never heard anything like that before...
Sounds like the radio is turning itself on instead of off when it gets the "key removed" message over the CAN bus?
Posted: Wed Aug 20, 2008 2:53 pm
by Thorny
Slightly o/t nut my stereo is always on when i start the car even when it was off when i turned it off - is that normal?
Posted: Wed Aug 20, 2008 2:54 pm
by rAudiguy
mine did that too....
Posted: Wed Aug 20, 2008 4:02 pm
by pippyrips
Thorny wrote:Slightly o/t nut my stereo is always on when i start the car even when it was off when i turned it off - is that normal?
Mine does whatever it was doing when the key was removed last time - off or on
Posted: Wed Aug 20, 2008 4:26 pm
by PetrolDave
pippyrips wrote:Mine does whatever it was doing when the key was removed last time - off or on
Same here - that's what they're supposed to do.
Posted: Wed Aug 20, 2008 4:30 pm
by rAudiguy
Before I had this problem if I had turned the music down or muted it for what ever reason when I'd get back in it would always be on again, not very loud but loud enough. I know you can change the settings but like you guys say it would nice if it did what ever it what last left at.
Posted: Wed Aug 20, 2008 5:41 pm
by PetrolDave
When you turn the iginition back on it does 2 things:
1) the radio goes back to the state it was when you turned the ignition off
2) the volume is reset to a "standard" level, so if you had muted it it will be back on, and if you were listening to it loud it will be quieter - that's just how Audi have decided to make it work
Posted: Thu Aug 21, 2008 2:35 pm
by Thorny
ok - so anybody know how to fix mine? or is it a dealer job?
Posted: Thu Aug 21, 2008 5:19 pm
by PetrolDave
Thorny wrote:ok - so anybody know how to fix mine? or is it a dealer job?
If you are still in warranty - then dealer job.
Posted: Thu Aug 21, 2008 9:40 pm
by dom888
i had this problem years ago in a bmw and it turned out to be a faulty key. try using your spare key and see if it still does it - worth a try i guess?
Posted: Fri Aug 22, 2008 9:13 am
by Thorny
great - will try that - thank you
