Page 1 of 4
what temp does your oil get up to?
Posted: Sat Aug 16, 2008 8:47 pm
by booski
I was just wondering because my temperature when driving gently is approx 100 celsius but on a good hard run i've hit 119 celsius. Is this what you guys have noticed?
RE: what temp does your oil get up to?
Posted: Sat Aug 16, 2008 9:00 pm
by S4INT
Mine is around 100 degrees normal driving, but I've had mine up to 130 degrees on track and hard driving in the Alps
Posted: Sat Aug 16, 2008 9:04 pm
by EuroSag
Yeah, had various differen't B7 RS4's all up to the 120 ish mark quite frequently.
Re: RE: what temp does your oil get up to?
Posted: Sat Aug 16, 2008 9:16 pm
by booski
Gumball3000 wrote:Yeah, had various differen't B7 RS4's all up to the 120 ish mark quite frequently.
3 B7 rs4's wow! why?
good to know 120 isn't abnormal, thanks fellas
RE: Re: RE: what temp does your oil get up to?
Posted: Sun Aug 17, 2008 9:26 am
by Ozrs4
138 degrees on skid pan
Posted: Sun Aug 17, 2008 11:14 am
by MikeD
There was a thread on this same topic some time back, I get to 138 on normal roads but opening the tap a bit , talking to Audi Germany re this due to the fact that oil starts to break down at 118 to 120ºC area so we loose above 50% of the oil's capability to protect..
I am changing the oil at least once every 14days to try to keep the motor A1 while Audi decide what to do. Last I heard they were due to send an engineer to Spain to work on my car but as of now still not seen him. But we do have average air temp of above 35ºC so that wont help, but even so. I found that adding water wetter to the cooling system helped by about 5 to 8ºC and also helped the oil warm up quicker in the mornings. When I get more from Audi I will make sure you all see their reply.
Mike.
Posted: Sun Aug 17, 2008 11:18 am
by dom888
I use Water Wetter and it took it down by 5ºC.
Posted: Sun Aug 17, 2008 12:09 pm
by SR71
MikeD,
Have you spoken to the gurus (Guy) at Opie Oils (
http://www.opieoils.co.uk) about your issues?
They're extremely knowledegable and might be able to advise you temporarily on a high temperature solution...maybe you need to move away from a multigrade oil for the summer? Something like a "60" oil except that in a V8 which revs to 8000+rpm, in theory, thats not ideal...
I don't know enough though.....
I get all my oil from them - they're about the only place I know about in the country where I can find the Titan Fuchs factory fill oil for the RS4.
Just a thought....
Posted: Mon Aug 18, 2008 8:23 pm
by sonny
WOW those are high temps or maybe im NOT ragging m car hard enough!..lol
Normal drivign conditions are 96c and aspirated road drives (not track) around 106c
Posted: Wed Jun 17, 2009 2:05 pm
by SR71
Consistently 125C today....
Posted: Wed Jun 17, 2009 2:29 pm
by pippyrips
A steady 120c for me today too
Never seen higher than 109c before...
Posted: Wed Jun 17, 2009 2:32 pm
by Dom81
OK - where are you both? On a track?
Having said that, I was at 122 in traffic on Sun (after a good blast) and that was much higher than I've seen before...
Posted: Wed Jun 17, 2009 2:36 pm
by aidanjaye
The joys of having crap, wet weather....normal driving 98oC, thrashing it 105oC.
Posted: Wed Jun 17, 2009 2:39 pm
by P_G
Highest I've had is 114, normal drive is 94-101 degree celcius
Posted: Wed Jun 17, 2009 2:40 pm
by Dom81
aidanjaye wrote:The joys of having crap, wet weather....normal driving 98oC, thrashing it 105oC.
Me too - don't know what happened on Sunday!
