Range: 0 miles
Posted: Wed Apr 02, 2008 10:37 am
by theaxe
My car is parked at the station with the range meter reading zero. Will I make it to 2 miles to the petrol station?
My XKR used to do 30-40 miles on zero but I suspect German efficiency may mean that zero means zero...
RE: Range: 0 miles
Posted: Wed Apr 02, 2008 10:51 am
by Dom81
RE: Range: 0 miles
Posted: Wed Apr 02, 2008 10:53 am
by theaxe
Thanks, my searching skills clearly aren't very good.
This was interesting though:
Nickm wrote:I can get about 68 litres in mine! I use the button inside the filler entrance to release the air and allow more petrol! You can get about another 5 litres after the pump has stopped!
Will try that tonight.
Posted: Wed Apr 02, 2008 11:13 am
by P_G
If just gone to 0 then you'll easy get another 10 miles out of it, there is IIRC a 3 litre reserve.
I've never found this hallowed 'button' though.
Posted: Wed Apr 02, 2008 11:19 am
by PetrolDave
P_G wrote:I've never found this hallowed 'button' though.
Nor me - all I can find is the rubber buffer stop against which the filler flap rests when closed, and that can't be pressed in...
Posted: Wed Apr 02, 2008 11:48 am
by P_G
I'm glad it's not just me then....
Posted: Wed Apr 02, 2008 12:09 pm
by mbelle
It should be just inside where the fuel nozzle goes in, if the same as the B5 - looks like a rubber bit on the left
You should be able to pull your nozzle out slightly and push it with the fuel nozzle, then return the fuel nozzle to re-fill that extra bit
FYI - just the other day I was at 0 for 20 miles before refuelling my B5 RS4... was pretty scary though as I would have been VERY stuck if I ran out...
MB
Posted: Wed Apr 02, 2008 12:34 pm
by dom888
I've been told to change the petrol filter once this has happened.
Posted: Wed Apr 02, 2008 12:43 pm
by Marcus-RS4
The button is there - it is just inside the filler neck, on the left hand side, a little metal slider - makes you look a little strange at the pumps though
Posted: Wed Apr 02, 2008 1:33 pm
by Dom81
I found the button too. Never used it while filling, but had to reassure myself that it was there!
Posted: Wed Apr 02, 2008 1:45 pm
by JohnW
I regularly go '-20' in my B5 RS4. I have run out once, and that was around 28 miles, plus an uphill climb. When your about to run outyou will hear the pump whine much louder than it normally does. Even when this starts you have a couple of miles left.
Posted: Fri Apr 04, 2008 8:56 pm
by Nickm
The button is good! I am getting 330miles out of a tank by pressing it! Makes your finger dirty though!!!!!!!!!!
