Cold rev limit
Posted: Sat Mar 15, 2008 8:58 am
by caldy
Having had my car re-mapped by Jeroen at JDE, included was a lowering of the cold running upper rev limit to 4,000 rpm. However, the Driver Info Display still reads 7,000 rpm. Any clever techies out there know how to change the reading?
RE: Cold rev limit
Posted: Sat Mar 15, 2008 9:56 am
by audijohn
If you do change the reading, the Service team will know you've tampered, beware; the germans are puting more "Feedback INFO" into there cars now, this info is accessed once the car is coupled to the computer systems @ said service centre. This can lead too lost warrantee.
Be careful.
RE: Cold rev limit
Posted: Sat Mar 15, 2008 1:00 pm
by PetrolDave
Not seen any way of doing it. I reckon it's "hard coded" into the instrument cluster.
Cold rev limit
Posted: Sat Mar 15, 2008 4:39 pm
by caldy
The service team are going to know anyway when the engine bounces off the rev limiter at 4,000 rpm!
RE: Cold rev limit
Posted: Sun Mar 16, 2008 12:13 am
by Andyuk911
properly think it is a fault, LOL and report it to Audi ...
Posted: Sun Mar 16, 2008 2:11 am
by Lancia
I like the idea though of lowering it to 4000RPM, still enough power if you need it anyway and much kinder to a cold hunk of expensive metal.
Posted: Sun Mar 16, 2008 12:39 pm
by caldy
The engine is so 'revvable', even when cold, that it is surprising how often you reach the 4,000 rpm limit although trying to be careful.
Posted: Fri Mar 21, 2008 5:21 pm
by Pig
Why have it lowered? Surely its easier to just drive the car under a chosen limit when its cold?
Posted: Fri Mar 21, 2008 9:04 pm
by pippyrips
Got to be honest i have no problems keeping the revs low when cold. That said if i were having it mapped anyway why not
Posted: Fri Mar 21, 2008 10:54 pm
by caldy
Now it's idiot proof.
Posted: Fri Mar 21, 2008 11:13 pm
by Iain_S4
I thought the 7,000rpm rev limit was purely an advisory message on the DIS rather than a physical rev limiter. Obviously I've never felt the need to check this. I'm sure that I read it in the handbook but I can't be bothered going out to the garage to check right now.............could be wrong.
I assume that you have tried out the 4,000rpm limiter since having it re-mapped.
Posted: Sat Mar 22, 2008 7:33 am
by t_urbo
Iain_S4 wrote:I thought the 7,000rpm rev limit was purely an advisory message on the DIS rather than a physical rev limiter. Obviously I've never felt the need to check this. I'm sure that I read it in the handbook but I can't be bothered going out to the garage to check right now.............could be wrong.
The 7 k limit does cut the power and the 4k limit JD Eng sets it at works too, although he will set it to any limit you want.
Posted: Sat Mar 22, 2008 12:23 pm
by youry
I've asked to have that limiter set at 5000rpm as 4000rpm can be reached quickly.... but 7000rpm is really too high OEM...
