fitting a new wheel
Posted: Sat Mar 01, 2008 8:13 pm
by hunty
fitting a new wheel on Monday after the original was badly damaged.
can you swop over the pressure sensor and metal value or do you have to buy new from Audi?
Thanks in advance.
RE: fitting a new wheel
Posted: Sat Mar 01, 2008 9:23 pm
by beauphoto
Both should be fine as long as the valve was not damaged too. The sensor should certainly be OK.
Re: fitting a new wheel
Posted: Sat Mar 01, 2008 10:31 pm
by pippyrips
hunty wrote:fitting a new wheel on Monday after the original was badly damaged.
Thanks in advance.
No problem at all. If it does work afterwards it will be because it was damaged in the process of changing.
RE: Re: fitting a new wheel
Posted: Sat Mar 01, 2008 10:53 pm
by hunty
thanks for that guys.
Posted: Sat Mar 01, 2008 11:27 pm
by pippyrips
Thanks in advance.
meant to say if it DOESN'T work!
