DVD NOT EJECTING
Posted: Tue Feb 05, 2008 6:01 pm
by RED_ROCKET
I am trying to eject the dvd nav disc and getting nowhere..
help
RE: DVD NOT EJECTING
Posted: Tue Feb 05, 2008 6:02 pm
by theaxe
When the car leaves the factory the eject button is disabled. The dealer should unlock it as part of the PDI.
Posted: Tue Feb 05, 2008 6:06 pm
by RED_ROCKET
now what shall i do???
Posted: Tue Feb 05, 2008 6:22 pm
by Dom81
Do you know anyone with VAG-COM - it's an easy change...
Posted: Tue Feb 05, 2008 6:34 pm
by Dom81
If you find someone, they need address 37 or 56. Then choose adaptation channel 067, and change value from 255 to 001
Posted: Tue Feb 05, 2008 7:18 pm
by Stefaab
I had the same problem. The dealer enabled the ejectbutton when the car was there for service.
Re: RE: DVD NOT EJECTING
Posted: Tue Feb 05, 2008 7:44 pm
by theaxe
RED_ROCKET wrote:now what shall i do???
Erm, take your car to a dealer...
Posted: Wed Feb 06, 2008 8:32 pm
by P_G
Does it make any sort of noise when you press the button (whirring etc?) If so and still nothing it could be that the tray loading motor or mechanism is damaged, the a new RNS-E unti is required under warranty. If not it is likely to still be locked as previously said.
Posted: Thu Feb 07, 2008 1:47 pm
by RED_ROCKET
it has been unlocked.
Posted: Fri Feb 08, 2008 11:10 am
by brice9
I had a similar problem when i first bought my car, i had the Audi ipod unit fitted by a local in car sounds company. Audi said they had to disconnect the ipod unit, and then the sat nav disc came out no problem!! sounds rreally strange, but it worked, i have no idea why this would affect the sat nav disc??
worth a try?
Posted: Fri Feb 08, 2008 11:16 am
by PetrolDave
brice9 wrote:Audi said they had to disconnect the ipod unit, and then the sat nav disc came out no problem!!
Hmmmm? Don't know that I believe them. The iPod interface connects to the CD changer interface and the DVD goes into the internal drive which is completely unconnected to that. I think the Audi dealer may have told you a porky there.
Anyway RED ROCKET's problem has already been solved, by getting the drive lock disabled (which should have been done at the PDI).
