Sport button problem
Posted: Fri Dec 14, 2007 9:16 pm
by taz21
Hi can any one help please, when i press my sport button on the steering wheel,the seats inflate,but the exhaust sound doesnt change?
No exhaust valve mods have been done.
RE: Sport button problem
Posted: Fri Dec 14, 2007 9:21 pm
by reevesroadster
did you press the "start" button
Posted: Sat Dec 15, 2007 11:04 am
by Pig
Trip to the dealer i would say.
Posted: Sat Dec 15, 2007 11:07 am
by t_urbo
At idle activate sport button and look to see if the flaps are open, if they are then its working.
Posted: Sat Dec 15, 2007 12:08 pm
by Ozrs4
and have a quick check to see if the vacuum line has became detached accidentally!
Re: RE: Sport button problem
Posted: Sat Dec 15, 2007 11:37 pm
by taz21
t_urbo wrote:At idle activate sport button and look to see if the flaps are open, if they are then its working.
Thanks for the reply!
But how and were do i need to look to see if the flaps are opening?
Posted: Sat Dec 15, 2007 11:39 pm
by taz21
Ozrs4 wrote:and have a quick check to see if the vacuum line has became detached accidentally!
Thanks mate!
please can you tell me were the vacum pipe is?
RE: Re: RE: Sport button problem
Posted: Sat Dec 15, 2007 11:48 pm
by t_urbo
The flaps are located in the tail pipes, they are a few inches back from the end of the exhaust.
When the sport button is off you will see that one of the tails pipes on each side is shut, when you activate the sport button the flap opens and you will see up both tail pipes on both sides.
Posted: Sun Dec 16, 2007 2:06 am
by Ozrs4
and for the vacuum line, lie on the ground and look up where the valve attenuators are (the round thing next the the pipe) and there is a black rubber hose coming out from that- connecting to the small 90 degree white plastic adaptors which then connect to the smaller green rubber hoses (same on both left and right side). Hope that make sense! Cheers.
Posted: Sun Dec 16, 2007 8:43 am
by Nickm
At low rpms you will notice little difference. In sport mode the flaps open below 1000rpm (I think) and then re-open at 5,550 (I think) - so apart from looking, you need to go and give it some stick.... or listen very carefully without touching the throttle.
Posted: Sun Dec 16, 2007 7:29 pm
by taz21
Thank you TURBO, OZRS4 AND NICKM,all for your help.
problem sorted,the had been standing for a while so the flaps got a little stuck,when i checked the flaps they were open,but only half closeing when the sport botton was being switched of,hence couldnt hear the sound changing.
Thanks all again
Lots of good people on here!!
Posted: Sun Dec 16, 2007 7:33 pm
by taz21
problem sorted,the car had been standing for a while so the flaps got a little stuck,when i checked the flaps they were open,but only half closeing when the sport botton was being switched of,hence couldnt hear the sound changing.
Thanks all again
Posted: Sun Dec 16, 2007 9:22 pm
by RussianM3_dude
taz21 wrote:Lots of good people on here!!
Thanks dude.
